Bad Master Cylinder or Brake Booster?
Attention Brake experts,
I have a 95 accord with 140k and the brakes are going bad. The pedal sinks when braking. It also sinks when the car is off and I press and hold the pedal down. I was wondering if this can be caused by a bad master cylinder or can it be the brake booster.
Re: Bad Master Cylinder or Brake Booster? (sinister2c)
its the master cylinder, its an internal leaks inside the cylinder thats causing the pedal to sink....if its was ur booster..then u will have a hard time pressing the pedal....good luck
Re: Bad Master Cylinder or Brake Booster? (HoOridin_Kali_STyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoOridin_Kali_STyle »</TD></TR><TR><TD CLASS="quote">its the master cylinder, its an internal leaks inside the cylinder thats causing the pedal to sink....if its was ur booster..then u will have a hard time pressing the pedal....good luck</TD></TR></TABLE>
integra123
08-08-2006 05:52 PM
KekeK-18
10
04-28-2002 09:38 PM
