b20b in ej2 wont start but will when push started
Old 11-20-2009, 06:45 PM
eg94coupejdm's Avatar
Default b20b in ej2 wont start but will when push started
well i just finished up my swap and im having a problem. my car wont start unless i push start it. could it be the starter? just some info b20b with obd2 distributor and obd2 alternator with obd2 harness in my eg and a obd1 p75. please give me some help. thanks HT!
Old 11-21-2009, 08:36 PM
grant_demji's Avatar
Default Re: b20b in ej2 wont start but will when push started
check the connections at the starter to see if its making good contact, check for a fuse, otherwise its most likely the starter
Old 01-06-2010, 08:27 PM
EGR95's Avatar
try checking your batt.
Old 01-07-2010, 05:57 AM
fcm
Old Fart
fcm's Avatar
If bump starting, [push start] works check the starter, do a bypass jump, use a jumper wire, [12ga min.] and jump from batt. pos.(+) to the starter motor solenoid input, [plug in terminal at the starter motor], BE CAREFULL, make sure car is not in gear, if starter/starter solenoid are good the engine will crank, even if in gear and ign. switch off
Is the car a standard or automatic? 94
Old 01-07-2010, 09:28 AM
95itr-ej2's Avatar
try your earths, happened my civic and was earths
Old 01-08-2010, 12:16 AM
Lambo123's Avatar
like said above, check your starter solenoid.
Old 01-08-2010, 12:36 AM
civic-one's Avatar
X2 . . . check you starter. Direct if to the battery.
Jack Murphy
06-21-2017 06:23 PM
B18CivicEH2
05-06-2009 05:29 PM
da6er
07-08-2006 02:36 PM
zman
08-16-2005 02:11 PM
lazykiwi
11-27-2004 04:17 PM
Quick Reply: b20b in ej2 wont start but will when push started
