B20 bogging down on accel
B20 ej2
Bogs down while sitting or driving
It has no cat
Hi guys I have a high comp b20 that was running absolutely fine but I had an oil leak in the dizzy so I changed the seal inside and when I fitted it back on it bogs down all the time.
I obviously thought something went wrong with the dizzy so I changed it over to my friends one that I know works fine and the same thing happend.
iv changed the engine loom aswel because it was coverd in oil from the dizzy leaking still nothing
I just can't get my head around it all I did was change the dizzy seal and now this it ran fine b4 I'm leaning towards tps or map sensor
It has no cat
Re: B20 bogging down on accel
I'm also using hondata s300 so I can live datalog but I don't know what I'm lookin at it
Any help is much appreciated iv searched all ova and I can find loads of threads about it but no real answers
I put it in bk in the same place it came off originally but then when it wasn't working I put the other one and tried going back and forth and no matter what it still feels sort of blocked up
I just finished a problem similar to this, car ran fine but bogged under load, try another FPR KNOWN to work if you are still running the stock unit.
flexinb20
12-22-2010 04:07 PM
