B18A/18B/20B engine specs - Honda-Tech
Old 05-02-2005, 10:18 PM   #1
gamakichi77's Avatar
Default B18A/18B/20B engine specs
anybody here could give me all info on engine specs for B18A/18B/20B?....
gamakichi77 is offline   Reply With Quote
Old 05-03-2005, 03:58 PM   #2
95lstegman's Avatar
Default Re: B18A/18B/20B engine specs (acidburns_di)
which specs? i could write a short novel on them. what, in specific, are you interested in? power? general dimensions?
95lstegman is offline   Reply With Quote
Old 05-03-2005, 07:35 PM   #3
Default Re: B18A/18B/20B engine specs (95lstegman)
i want to make comparison between B18A/B and B20B block....wanna start my hybrids NA Vtec project now...
Old 05-03-2005, 09:09 PM   #4
95lstegman's Avatar
basically, the B20 has weaker sleeves, which may not hold up for too long, although 8000rpm should be okay on the sleeves. it will probably net you about 10whp. either block will need mods to support 8000rpm for long. such as main cap girdle, ARP rod bolts, just to name the basics.
Old 05-04-2005, 09:52 AM   #5
legendboy's Avatar
Quote:
I'd really like someone to have proof of this just once. As far as i'm concerned this is a bandwagon/rumor type thing.
legendboy is offline   Reply With Quote
Old 05-05-2005, 01:54 AM   #6
yea......i agree with you pal....there's a lot of champions using B20B blocks.....
but what i want is why most of tuner and racer prefer to use B18A/B rather than B20B?
Old 05-05-2005, 01:00 PM   #7
97L-esVeeTeg's Avatar
Default Re: (acidburns_di)
I ASSUME its easier to sleeve a b18 than a b20 with its 1 piece paper thin cylinder sleeves.
Modified by 97L-esVeeTeg at 10:38 AM 5/6/2005
97L-esVeeTeg is offline   Reply With Quote
Old 05-06-2005, 01:12 AM   #8
how about if i 'm using an CTR pistons in B18B block?.....is there any clearence problems?
Old 05-06-2005, 07:27 AM   #9
legendboy's Avatar
Default Re: (97L-esVeeTeg)
Quote:
Originally Posted by 97L-esVeeTeg
Its easier to sleeve a b18 than a b20 with its 1 piece paper thin cylinder sleeves.
haha you should make sure you have actually SEEN both sets of stock sleeves (and know something about sleeving) before making a comment like this to avoid looking like a dumbass
Old 05-06-2005, 07:44 AM   #10
JDMlover's Avatar
Who has the GSR tranny for sale?
JDMlover is offline   Reply With Quote
Old 05-06-2005, 07:49 AM   #11
JDMlover's Avatar
Do GSR trannies fit LS tegs?
Old 05-06-2005, 08:21 AM   #12
Default Re: (legendboy)
Quote:
I have seen b20 stock and b18 stock sleeves, but it is true i know nothing about sleeving and i am a dumbass, BUT i have seen with my own eyes both sets of sleeves
I'm not a complete idiot (although i may have come across as one) i have done work to both blocks, perhaps my hypothesis came off as fact and i apologize.
Old 05-06-2005, 08:26 AM   #13
Default Re: B18A/18B/20B engine specs (JDMlover)
Quote:
yes, MOST b-series parts are interchangeable
Old 05-06-2005, 08:37 AM   #14
Default Re: B18A/18B/20B engine specs (97L-esVeeTeg)
To add something if I may, b18a/b are a dime a dozen compared to the 700-800 price tag for the b20, also when you talk with most sleeving companies they normally charge about 100 bucks more for the sleeving of a b20 block, again i am assuming this is because of the design of the b20 sleeves (please dont flame i said ASSUMING).
bnib eagle esp h beam rods for b18a/b or b20 j spec For Sale 2 04-04-2011 04:04 PM
specs? seldon Acura Integra 10 08-28-2008 12:34 AM
b18a1 torque specs LS94tegra Acura Integra 6 02-03-2008 06:06 PM
B18C3 Specs shorto85 Acura Integra 8 02-08-2005 04:54 PM
B20Z - CRV or B18C???? B18C-Hatch13 Hybrid / Engine Swaps 8 12-26-2001 10:28 AM
Tags
18b, acura, b18, b18a, caps, engine, gsr, honda, installing, ls, main, motor, specs, stock, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
