how do you take off and install a fuel rail correctly???
Old 05-05-2005, 09:12 AM
HT Username's Avatar
Default how do you take off and install a fuel rail correctly???
my 2nd injector is leaking where the fuel rail and injector meet so I think its a O ring. I searched on how to do this but all i found was other people having problems and people telling them to use thread sealent as well and or having them IM them so they could help. Well now I need help bad. How Do I removed and Install the fuel rail properly?
Jason
Old 05-05-2005, 10:08 AM
drdisco69's Avatar
Default Re: how do you take off and install a fuel rail correctly??? (JasonHatch94)
It's just the 2 bolts to remove it, and while you're in there you may as well replace the o-rings. Put a little silicone spray or ATF or something on them to lube them up when you put the rail back on, and make sure you don't pinch any of the seals. Slide it down straight and put the bolts on. Have someone turn the key on (don't start the car) and watch for leaks. Cycle the key a few times to make sure it's ok, then crank 'er up!
PS, Thread sealer
tgreaves's Avatar
Put some hand soap on the o-ring when you push the injectors into the rail, What you probably did was broke the o-ring when you pushed it in..
I always install the injectors into the fuel rail and then put the rail on to the manifold..
Old 05-05-2005, 11:27 AM
Default Re: how do you take off and install a fuel rail correctly??? (tgreaves)
yea i think thats what happend to. I have a new set of o rings coming but should have those on soon. how do i get rid of the fuel pressure before i take off the rail?
Old 05-05-2005, 11:30 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonHatch94 &raquo;</TD></TR><TR><TD CLASS="quote">yea i think thats what happend to. I have a new set of o rings coming but should have those on soon. how do i get rid of the fuel pressure before i take off the rail?</TD></TR></TABLE>
Close your eyes and loosen the bolt..
Old 05-05-2005, 05:24 PM
2SlowDC's Avatar
take off ure gas cap.
take off ure fuel rail and put oil around the new oring b4 u slide it back in to make sure it dosnt pinch while it goes in.
also dont tighten your fuel rail bolts too tight becuase it can pinch ure orings and may leak again.
Old 05-05-2005, 06:13 PM
suspendedHatch's Avatar
Default Re: how do you take off and install a fuel rail correctly??? (No-Tec)
On top of your fuel filter you have a small fuel service bolt. Put some shop rags around it and open it up.
That's why you use the repair manual...
Old 05-06-2005, 07:14 AM
Default Re: how do you take off and install a fuel rail correctly??? (shaundrake)
thanks guys on all the help. it took me all of 10 min to fix her this morning so again thanks again. it was just a faulty o ring. thanks
Jason
return_2020
09-01-2005 07:12 PM
garados
12-21-2003 10:17 PM
satan_srv
12-11-2003 08:59 PM
RTW DC2R
01-26-2003 08:07 PM
thehondaguru
10-11-2002 05:33 AM
Quick Reply: how do you take off and install a fuel rail correctly???
