b18 leaking oil
Banned
b18 leaking oil
i got a b18 head with b20 block. anyone have the oil feed line on this motor leak? every time i rev the engine i get oil spitting out by the filter (where the bottom end of the oil feed line is). for about 30 seconds oil was pouring out like a faucet and the oil was muddy looking. like when u take the oil pan off. any suggestions for this type of leak?
also there is an LS throttle cable on this motor which is about 6-8 inches too long. very low idle and accelerator gets stuck from the cable drag i guess. any suggestions? oh i forgot, im not sure which ecu to use for this i know its an obd1 but any certain one? whats the point of vtec if the car wasnt factory programmed for it.
any help will be appreciated
**90 ef hatch for sale**
did u use teflon tape on the threads of the feed line?is your oil filter tight?u might have gotten something in the threads of the feed line and it is cause a leak!
Banned
well see the thing is that it WAS NOT leaking on the 20 mile drive back to my house from where i was that evening. i noticed a small drip but the next morning i started it up, revving the engine then noticed a huge pool that came from me revving. it wasnt dripping over nite.
