b16a head on b20a "the frankinstien" - Honda-Tech
Old 03-06-2004, 12:55 PM   #1
miketurbohonda's Avatar
Default b16a head on b20a "the frankinstien"
hey i brought a b20a block and i was reading the honda building book and you can bolt a b16a head on the b20a block with ease on problems and make it vtec aswell just by hooking up oil line from oil pressure sensor on back of block.and a ecu
but does this work on the b20a gold top. or the b20a black top????
your help is much appreciated
thanks
mike
miketurbohonda is offline   Reply With Quote
Old 03-06-2004, 01:38 PM   #2
non-VTEC's Avatar
Default Re: b16a head on b20a "the frankinstien" (miketurbohonda)
you bought a B20A? you might as well use it as a boat anchor.....those B20A's found in the older 2.0 preludes are useless. you can rev them over 6500rpm without blowing them up.
the B20 you NEED is from the 98+ Honda CR-V. engine codes B20B or B20Z. if properly built they can take 8500rpm or maybe even more.
oh and i have no idea what your referring to about gold or black tops? what are those supposed to mean?
non-VTEC is offline   Reply With Quote
Old 03-06-2004, 08:08 PM   #3
virginia_dude's Avatar
Default Re: b16a head on b20a "the frankinstien" (non-VTEC)
Second that. You have to use a B20B or a B20Z, the B20A is about as usefull for high performance as a HF engine is.
virginia_dude is offline   Reply With Quote
Old 03-06-2004, 08:24 PM   #4
Kendall's Avatar
Default Re: b16a head on b20a "the frankinstien" (virginia_dude)
Quote:
Originally Posted by virginia_dude
Second that.
And a third.
Kendall is offline   Reply With Quote
Old 03-06-2004, 10:07 PM   #5
b20a the 2 litre dohc motor
whats wrong with that???
have you not seen the browny/gold top motor in the 86model preludes and the black top rocket cover in the later model preludes
i was going to rebuild b20a with forged pistons etc.. for when my turbocharged 1600 ZC dohc motor blows up.
Old 03-06-2004, 11:21 PM   #6
JDMorgan's Avatar
a b20a is a shorter block. some1 figure out bore and stroke on it and deck height too while ur at it.
JDMorgan is offline   Reply With Quote
Old 03-07-2004, 12:25 AM   #7
Rusty Shackleferd's Avatar
Default Re: (KraZEtEggIE)
Back in the day people would use those cranks in ls blocks
My friend had one (81x95 ls motor in a coupe). It had crazy mid range but nothing above 7grand.
Probly would have made for a pretty good tow vehicle though......lol
Rusty Shackleferd is offline   Reply With Quote
Old 03-07-2004, 03:11 AM   #8
Default Re: (10secondbeast16)
i thought a frankinstein motor was a k20 head on a tsx block
jeremy. is offline   Reply With Quote
Old 03-07-2004, 10:13 AM   #9
dfoxengr's Avatar
Default Re: (ek_jeremy)
Quote:
uzzled: i hope youre being sarcastic. although this is one variation with the k series motors
dfoxengr is offline   Reply With Quote
Old 03-07-2004, 11:00 AM   #10
red91sit's Avatar
Did it bolt right up to the ls rods? I really want to do the exact opposite lol but i don't want to buy new rods.
BTW was that crank from a 88-91 prelude or a pre 87 or older.
Also all 3rd gen motors are black valve covers and the single cammers i think had gold tops but these motors are completely different from the black tops.
red91sit is offline   Reply With Quote
Old 03-07-2004, 11:51 AM   #11
Default Re: (red91sit)
you use the ls block, b20a crank and b16a rods
Old 03-07-2004, 02:22 PM   #12
red91sit's Avatar
These all bolt right together? no machine work needed?
Old 03-07-2004, 02:40 PM   #13
dfoxengr's Avatar
thees some machine wor. searc lsvtec on google
b16a2 head b20b block, do i use gsr head studs? fv8s Tech / Misc 6 03-09-2010 06:47 AM
will a b16a2 head fit a b20a block? RACEPAK Hybrid / Engine Swaps 14 07-11-2006 05:57 AM
what pistons for b18b block with b16a head austrian type-R Hybrid / Engine Swaps 2 11-04-2004 02:23 PM
head of B16A2 on a block B20A7?? Special B Hybrid / Engine Swaps 4 07-03-2004 10:47 AM
b16a head and block wanted b20hatch For Sale 8 12-16-2002 01:00 PM
Tags
88, 91, anchor, b16a, b20a, block, boat, dohc, goldtop, head, honda, k20a, ls, prelude, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
