b16a 96 civic flashing cel code wen trying to read codes
i swapped my harness for a 96 ex harness an converted my injectors an distributor to obd1 with the conversion adapters but now i have a cel witch i didnt have b4 i did all the clips correct i belive cuz i just matched wat i had pluged in b4 now wen trying to pull codes it just shows a long flashing code it just keeps flashing/ blinking idky thank yu for ur help
Re: b16a 96 civic flashing cel code wen trying to read codes
yes i can an beat example is i jump the service connector an cel just keep blinking long blinks no codes it just keeps flashing every 5 secs an doesnt stop i will show yu tho give yu a better idea
Okay, well, it is showing you the code/s. Long blink is 10, short blinks are 1.
2 long blinks, 20.
2 long blinks and 7 short blinks, 27.
The flashing is close together and when there is a pause, that is the end of the code.
Record the amount of flashes. it is a continuous cycle. it will keep flashing codes until you either pull the jumper or clear them. Good luck. And, where is that video??
2 long blinks, 20.
thank yu for the reply i have the video but caint post on hea do to me not having the youtubbe account i have the video an can send yu it threw email if yu have 1 ill send it thank you again also this all happened after replacing my harness to an ex harness 0bd2 an only sensor that was diff was the iat semsor but i kno for sure its rite only thing i think is rong is injecrors or my o2 sensor car mva had a cel light i would put in access an the cel would b on an turn rite off like it should swapped harness an got a cel
