B series Transmission question
Old 10-09-2001, 05:05 PM
New User
H22CIVIC's Avatar
Default B series Transmission question
Are all the gears of all Bseries motors interchangeable. For example, I have a LS tranny complete, but I have a full set of gears, synchros, etc from a GSR laying around. Can I put that in the LS tranny?
Old 10-09-2001, 09:45 PM
New User
smp534's Avatar
Default Re: B series Transmission question (H22CIVIC)
most likely not
check out gearig stuff here:
http://hybrid.honda-perf.org/tech/variants.html
[Modified by smp534, 6:52 AM 10/10/2001]
Old 10-10-2001, 04:12 AM
sohc_boy's Avatar
i think they are interchangeable. i'm not sure but i have heard that people mix the gears from the ls and gsr to give them better gearing.
Old 10-10-2001, 02:21 PM
Colin's Avatar
i'm not sure if all of it is interchangable, and i'm not sure if all the gsr parts will fit into an ls housing, but i know some things can be swapped.
i know a couple of people who have taken j1/y1/s1 and ys1 vtec trannies, then pulled the 5th gear out and replaced it with the 5th gear from their ls tranny (ys1). Thus the 1st 4 gears are short gears for racing and such, while the 5th gear retains good gas mileage at high speeds like when you're on the freeway.
I only know this works with the b series cable trannies, i don't know much about the hydro ones.
SoCaLeK
Transmission & Drivetrain
12-02-2008 06:16 PM
b20vtecEK
01-25-2005 05:27 AM
jdm_gsr
02-11-2004 05:55 AM
Grandprix
09-05-2002 11:07 PM
Quick Reply: B series Transmission question
