B-Series Cam Spec List (Specs all @1mm)
#29
Re: B-Series Cam Spec List (Specs all @1mm)
So... I'm assuming the higher the lift and the duration the better? I'm new to this technical aspect of cams.. so I'm trying to understand...
#31
ok i call bullshit on the posting 2k civic si put up on the du*ation on both intake and exhaust side on those gs-* cams. how does stock cams have bette* du*ation then the whole cam list posted? those numbe*s have to be w*ong.
can you guess what key b*oke on my keyboa*d? lol
#32
#34
Hey all, ive been a long time lurker and benefiter of the information on this site. Recently I've been having huge issues with the BC0013, so set about buying some new cams, but wanted to be able to make some sort of comparison (i know the below numbers cant visualize ramp rate and such) but as an indicator and to keep this great sticky current please see below some modern day cams at 1mm. If an admin wants to move these specs to the front page my all means please do.
The Below are all measured at 1mm and are straight from the manufacturers mouth.
Skunk2 Tuner Series Stage 1
Int-251 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Skunk2 Tuner Series Stage 2
Int-264 dur. / 12.2mm lift
Exh-266 dur. / 11.8mm lift
Skunk2 Pro Series 1+
Int-258 dur. / 12.6mm lift
Exh-260 dur. / 11.9mm lift
Skunk 2 Pro Series 2+
Int-261 dur. / 12.6mm lift
Exh-272 dur. / 11.6mm lift
Brian Crower Stage 3 (BC0013)
Int-268 dur. / 12.6mm lift
Exh-260 dur. / 12.6mm lift
#35
I like to party
I've noticed a lot of these "official cam spec" threads are wrong.
Here's some specs I've collected over the years that I feel are correct that are measured off the actual intake and exhaust valve movements at 1mm, not "advertised specs".
B16 -
Intake lift - 10.34
Intake duration - 235
Exhaust lift - 9.44
Exhaust duration - 230
ITR (96-97) -
Intake lift - 11.45
Intake duration - 240
Exhaust lift - 10.52
Exhaust duration - 235
CTR/ITR (98+) -
Intake lift - 11.4
Intake duration - 243
Buddy Club Spec 3 -
Intake lift - 11.6
Intake duration - 304
Exhaust lift - 10.7
Exhaust duration - 294
Buddy Club Spec III+ -
Intake lift - 11.4
Intake duration - 250
Exhaust lift - 11.8
Exhaust duration - 245
Buddy Club Spec IV -
Intake lift - 12.3
Intake duration - 266
Exhaust lift - 11.8
Exhaust duration - 262
Buddy Club Spec VI -
Intake lift - 11.8
Intake duration - 253
Exhaust lift - 11.9
Exhaust duration - 243
JUN III -
Intake lift - 12.0
Intake duration - 265
Exhaust lift - 11.5
Exhaust duration - 265
Spoon Sports High Cam -
Intake lift - 11.5
Intake duration - 256
Exhaust lift - 11.1
Skunk2 Tuner1 -
Intake lift - 11.6
Intake duration - 252
Exhaust lift - 10.9
Exhaust duration - 249
Skunk2 Tuner2 -
Intake lift - 12.3
Exhaust lift - 11.8
Skunk2 Tuner3 -
Intake lift - 12.8
Intake duration - 273
Exhaust lift - 11.5
Exhaust duration - 273
Skunk2 Pro1 -
Intake lift - 12.6
Intake duration - 257
Exhaust lift - 11.6
Exhaust duration - 263
Skunk2 Pro2 -
Intake lift - 12.5
Intake duration - 263
Exhaust lift - 11.6
Skunk Pro3 -
Intake lift - 12.7
Intake duration - 270
Exhaust lift - 11.9
RM24x -
Intake lift - 12.0
Intake duration - 268
Exhaust lift - 12.0
Exhaust duration - 268
RM25x -
Intake lift - 12.0
Intake duration - 275
Exhaust lift - 12.0
Exhaust duration - 275
Toda Spec A
Intake lift - 11.6
Exhaust lift - 11.2
Exhaust duration - 240
Toda Spec B
Intake lift - 12
Intake duration - 255
Exhaust lift - 12
Toda Spec C
Intake lift - 12.5
Exhaust lift - 12.5
Exhaust duration - 255
BISI Level 3+ CAMS -
Intake Lift - 12.2
Intake Duration - 276
Exhaust Lift - 11.7
Exhaust Duration - 276
B16 -
Intake lift - 10.34
Exhaust lift - 9.44
ITR (96-97) -
Intake lift - 11.45
CTR/ITR (98+) -
Intake lift - 11.4
Buddy Club Spec 3 -
Intake lift - 11.6
Exhaust lift - 10.7
Intake lift - 11.4
Exhaust lift - 11.8
Intake lift - 12.3
Exhaust lift - 11.8
Intake lift - 11.8
Exhaust lift - 11.9
JUN III -
Intake lift - 12.0
Exhaust lift - 11.5
Intake lift - 11.5
Exhaust lift - 11.1
Skunk2 Tuner1 -
Intake lift - 11.6
Exhaust lift - 10.9
Skunk2 Tuner2 -
Intake lift - 12.3
Exhaust lift - 11.8
Skunk2 Tuner3 -
Intake lift - 12.8
Exhaust lift - 11.5
Skunk2 Pro1 -
Intake lift - 12.6
Exhaust lift - 11.6
Skunk2 Pro2 -
Intake lift - 12.5
Exhaust lift - 11.6
Skunk Pro3 -
Intake lift - 12.7
Exhaust lift - 11.9
RM24x -
Intake lift - 12.0
Exhaust lift - 12.0
RM25x -
Intake lift - 12.0
Exhaust lift - 12.0
Toda Spec A
Intake lift - 11.6
Exhaust lift - 11.2
Toda Spec B
Intake lift - 12
Exhaust lift - 12
Toda Spec C
Intake lift - 12.5
Exhaust lift - 12.5
Intake Lift - 12.2
Exhaust Lift - 11.7
#38
The new version of Skunk2´s has changed the specs
For example:
Skunk2 Tuner Stage 1 11.50@251° / 10.80@252°
Skunk2 Tuner Stage 2 12.27@264° / 11.81@266°
Skunk2 Tuner Stage 3 12.55@266° / 11.81@277°
Skunk2 Pro-Series 1+ 12.65@258° / 11.90@260°
Skunk2 Pro-Series 2+ 12.60@260° / 11.65@272°
check the website...
For example:
#40
So i have a b20 high comp block that in going to be putting my b16 head on that has itr cams should i upgrade my springs and retainers to gsr. I see people saying gsr and itr are identical in this aspect but what about the springs from the b16 head?
#41
I like to party
GSR and ITR springs are most definitely NOT identical.
What your dumb friends are talking about, is that GSRs have a dual valve spring on the intake side. (ITRs have dual valve springs on both sides) Even so, they are not the same spring.
Just find some ITR springs, they're cheap.
#42
How do you measure the lift?
i have a set of cams and I don’t know what they are. It came out of a B16 head. I came up with a lift of 6.2 for intake Vtec center lobe.
They dont look worn out
#45
Basically, if you have a GSR head and want to install Type R springs and cams, you move your GSR Intake inner and outer springs over to the exhaust side (discarding the exhaust single springs) and buy a set of ITR Intake inner and outer springs and install them on the Intake side. Drop in the cams, set your valve lash and drive.
2LEM1, you did an incredible amount of work to compile all of that information and I, as well as many others in this community, appreciate your effort and willingness to share it.
#47
The VTEC rocker ratio on a "B" series is 1.55:1. You have to multiply your measurement by the rocker ratio to get the lift at the valve. You are measuring at the lobe essentially... not what you will see advertised by most cam manufacturers.
As an example, look here: http://briancrower.com/makes/honda/b16ab18c.shtml
#48
As an example, look here: BrianCrower.com | RunBC.com // Honda // B16A / B18C
5.6 X 1.55 = 8.68
THIS LOOKS LOWER THAN STOCK. THEY TURBO CAMS THEN?
#49
Dude alot of those are way wrong. Today VTEC killer cams are 285.295, or 305. And the b series type r b18 has smaller Intake valves than the b16b type r. They're not the same.
seelback
09-11-2015 03:30 AM
