Axles - inner joint difference?
Old 03-30-2002, 08:52 AM
-TJ
-TJ's Avatar
Default Axles - inner joint difference?
Are the <U>Right Hand Axle</U> inner joints different between 90-93 integra and 94+???
Old 04-10-2002, 11:49 AM
-TJ
-TJ's Avatar
Default Re: Axles - inner joint difference? (-TJ)
So, no one has ever thought to compare the right side inner joint between 90-93 and 94+ integra?
Old 04-10-2002, 12:30 PM
sgT
sgT's Avatar
driver side inboard joint should be the same between 90-93 and 94+
I have used 94+ axles in 90-93 trans with no problems.
Old 04-10-2002, 12:35 PM
-TJ
-TJ's Avatar
Default Re: Axles - inner joint difference? (sgT)
Thank You!
Old 04-11-2002, 04:20 PM
driveshaftshop's Avatar
hey
the right inner joint is the same from 90-2000
Old 04-11-2002, 08:25 PM
RMS
RMS's Avatar
Default Re: Axles - inner joint difference? (driveshaftshop)
'99-00 are a very different design internally. Also, the early joints use short cups and have two different diameters for the bearing pegs...leading to broken axles and sometimes trans cases, too if the axle is just a little short. We replace the short cups with the later deep ones (JDM cups are deep even on the early B16s). Hope that helps.
itralex
03-02-2007 04:03 PM
95_red_dc
04-24-2006 07:02 AM
xH22xTEGx
01-12-2006 06:48 AM
DEVIN22CBR
06-25-2003 08:00 PM
Quick Reply: Axles - inner joint difference?
