ARP ROD BOLTS Torque Specs - Honda-Tech
Old 12-12-2005, 08:19 PM   #1
CA6VTEC's Avatar
Default ARP ROD BOLTS Torque Specs
<FONT COLOR="royalblue"> I just picked up some eagle rods w/ the arp rods bolts, but they didn't come w/ the torque spec sheet.. I tried going to arp, but my shitty 56k is killing me. </FONT>
CA6VTEC is offline   Reply With Quote
Old 12-12-2005, 08:32 PM   #2
onepoint6i's Avatar
Default Re: ARP ROD BOLTS Torque Specs (CA6VTEC)
what bolts did they come with? more than likely 5/16" ARP 2000-3/8" bolt head?
you should invest in a Rod bolt stretch gauge, much more accurate than a torque wrench for Arp rod bolts..
onepoint6i is offline   Reply With Quote
Old 12-12-2005, 10:28 PM   #3
Sliced Beard's Avatar
Default Re: ARP ROD BOLTS Torque Specs (onepoint6i)
I suggest you measure the rod bolt stretch and set them to ARP specifications. Call up ARP and they will give you the exact specification.
I have a stretch guage that I could set your stretch for you with but I am too far away. Your best bet is to either torque them to factory +2 ft-lb or send it off to the machine shop and have them measure it to proper stretch.
Sliced Beard is offline   Reply With Quote
Old 12-12-2005, 11:17 PM   #4
budsmachine's Avatar
Default Re: ARP ROD BOLTS Torque Specs (DirtySol)
Quote:
Do not torque to factory specs!!!!! most all eagle rods untill recently use 5/16 bolts (close to 8mm). factory b16 and b18c rods have 9mm bolts. if you torque to factory 33lbs you will over stretch the bolts possibly causing breakage. call eagle 662-796-7373, they will need to know the socket size of the head and the markings on the head(eagle8740 or eagleS2000 i think).
budsmachine is offline   Reply With Quote
Torque spec for a z6 eagle rods w/ arp bolts b18c4g Honda Civic / Del Sol (1992 - 2000) 1 08-15-2007 05:35 PM
SOHC: ARP 2000 rod bolt torque specs in D16A6 W O T Forced Induction 12 04-24-2007 05:31 AM
b18b rods arp rod bolt torque..torque spec? psegs80 Acura Integra 7 11-13-2005 10:33 AM
USDM GSR parts. 4 wheel disc setup. GSR seats, interior and more. Em0ne For Sale 31 08-28-2005 01:08 PM
FS: 81mm and 81.5mm ITR pistons. 81mm ITR pistons with LS rods Em0ne For Sale 20 08-20-2005 12:01 PM
Tags
2000, 38, 9mm, arp, b18c, bolt, bolts, eagle, rod, series, spec, specifications, specs, stretch, torque, tq
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
