another "my fuel pump doesnt turn on" thread..
Old 03-14-2007, 12:56 PM
blackeg's Avatar
Default another "my fuel pump doesnt turn on" thread..
yeah, my fuel pump wont come on. if i jump the pins in the main relay harness, the pump come on, but if i havve the relay plugged in it doesnt come on. ive tried 3 different relays, and find it hard for all 3 off them to be broken. what else could it be besiddes main relay?? again, if i jump the pins it works..
Old 03-14-2007, 01:24 PM
Perfectionist's Avatar
Default Re: another "my fuel pump doesnt turn on" thread.. (blackeg)
The pump only runs for about 2 seconds while the main relay is energized when the ignition is first turned to "run". The relay will energize again when the ECU sees pulses from the distributor. Are you checking for power during this period?
Old 03-14-2007, 04:52 PM
blackeg's Avatar
Default Re: another "my fuel pump doesnt turn on" thread.. (Perfectionist)
no i havent checked for power. what i did was give power to the car, jump the relay harness and i can hear the fuel pump running in the tank. with the pins jumped the pump constantly runs. the car is still a working shell, there is no motor or battery so im using a jumperpackk
Old 03-14-2007, 08:36 PM
Toadfart's Avatar
http://www.marklamond.co.uk/te...y.htm
Old 03-15-2007, 02:09 AM
blackeg's Avatar
dumb question, i dont have to have an ecu plugged in for this to work do i?
additionaly, my engine light isnt coming on then going off when i put power to the car, but there is a possibility the bulb is burnt/missing, i just havent checked yet
Old 03-15-2007, 08:41 AM
Toadfart's Avatar
You need to have an ECU plugged in.
Old 03-15-2007, 11:46 AM
blackeg's Avatar
Default Re: another "my fuel pump doesnt turn on" thread.. (Toadfart)
right, i though so i was just checking. try to avovid missing the little things...
oresama
29
10-30-2020 12:02 AM
slowEGles
05-13-2013 06:16 PM
4banger1986
11-26-2008 02:42 PM
insomniac791
01-22-2004 04:23 PM
Quick Reply: another "my fuel pump doesnt turn on" thread..
