ac compressor bypass pulley
does anyone know if there is an aftermarket bypass pulley for 08 Honda civic ex?
also is it possible to remove the ac compressor and just use a dx belt because the dx does not come with ac?
Re: ac compressor bypass pulley
Under full throttle, the A/C clutch disengages in favor of engine output. You will see no increase in engine power by deleting it. Since you will be installing a bypass pulley, the drag from the belt tension and bearing will persist, which makes installing a bypass pulley pointless at every level.
Put the compressor back on.
Mike Beachy
09-28-2019 12:15 PM
redacura
05-26-2008 03:57 PM
