99 Civic Engine noise. - Honda-Tech
Old 03-16-2017, 05:07 PM   #1
Default 99 Civic Engine noise.
First time on here just trying to get an another opinion on what noise is coming from my engine. I have a 99 Civic LX 4dr 5spd with a D16Y8 swapped into it. It runs great but I notice even when the engine is warm (not only cold) it sound like an engine tap coming from the valve train. I already adjusted the valves to Specs but the noise is still there just trying to get some other ideas. Thanks.
LitoEK is offline   Reply With Quote
Old 03-17-2017, 12:28 AM   #2
Default Re: 99 Civic Engine noise.
It's possible you have an exhaust leak. I would seafoam it and look for white smoke billowing anywhere from the exhaust manifold to the oxygen, most likely from the exhaust manifold if there is a leak.
holmesnmanny is offline   Reply With Quote
Old 03-17-2017, 03:31 AM   #3
It definitely doesn't sound like an exhaust tap. You can really hear it near the Cylinder Head.
Old 03-17-2017, 03:34 PM   #4
pogeeboy27's Avatar
Take a video and post it up.
pogeeboy27 is offline   Reply With Quote
Old 03-17-2017, 08:36 PM   #5
New to this site how do I post the video I have one.
Old 03-17-2017, 08:50 PM   #6
Quote:
https://youtu.be/zTcbjkzLz-I here's the video I posted on YouTube.
Old 03-18-2017, 10:35 PM   #7
Just watched your video. Sounds exactly like my car after I replaced the timing belt. After discovering this god-awful noise, I tore my timing belt job down piece-by-piece and found that the tensioner pulley bracket's "tooth" had slipped out of it's "cave"... if you know what I mean (the tensioner pulley has a protruding square piece that sits in a complimentary square hole on your engine). So I reset the "tooth" back into the little indent, put the belt back on, and cranked her over. After about 20 seconds of the same dreadful noise, my idle slowed from around 1500 to 900rpm and the noise gradually went away. I don't know if this has anything to do with what you're working with, but I thought I'd share my insight just in case it helps. And out of curiosity.. how long ago was the swap done? Has it always sounded like this?
dazasero is offline   Reply With Quote
Rattling noise coming from belts? 808CG1 Engine Management and Tuning 1 03-16-2013 05:19 PM
94 civic sohc vtec clicking noise ge_ej1 Honda Civic / Del Sol (1992 - 2000) 9 10-25-2007 12:04 PM
Help, I still cant figure out what is this ticking / hissing / static noise from motor... Azxster Honda Civic / Del Sol (1992 - 2000) 6 09-28-2007 08:16 PM
Engine Noise Fl. Man Honda Accord (1990 - 2002) 3 06-20-2007 06:29 PM
CLUTCH MAKING SQUEAKY NOISE???? vteckiller Acura Integra Type-R 3 04-20-2002 09:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
