97 civic condensor fan FUSE keeps blowing - Honda-Tech
Old 09-21-2009, 02:26 PM   #1
jc2801's Avatar
Default 97 civic condensor fan FUSE keeps blowing
I have a 97 civic lx stock d16. The A/C was working fine and all of sudden it stopped throwing cold air. I checked everything and the condensor fan fuse keeps blowing (the fuse box under the hood next to the battery). I replace it with a size 20 fuse and it blows right away so I put a 30 fuse and the compressor start working for about a minute and then blows. I checked the wires and there is no shortage. The condensor fan spins and the compressor works until the fuse blows.....I'm not sure if its the condensor motor or fan or something else, anyone know what's wrong or any advice? Thanks in advance.
jc2801 is offline   Reply With Quote
Old 09-21-2009, 06:18 PM   #2
fcm
Old Fart
fcm's Avatar
Default Re: 97 civic condensor fan FUSE keeps blowing
Never replace fuses with bigger ones, you can burn your car to the ground.
Fuse 56 - 20A, [hot at all times] in engine bay fuse box is power for the condenser fan and the A/C compressor clutch, through the condenser fan relay and the compressor clutch relay, power to the compressor clutch also goes through the "A/C Compressor Thermal Protector".
My guess is the condenser fan is good and the problem is the A/C compressor clutch coil or the A/C CTP switch.
A simple test is to unplug both the A/C compressor clutch relay and the condenser fan relay, using a jumper wire with a 10A fuse in it, jump the in/out terminals of the condenser fan relay plug, condenser fan will turn on, [ign. switch does not need to be on] let it run, if fuse does not blow remove jumper, plug condenser relay back in, start car and turn A/C on, install fused jumper on the in and out terminals of the compressor clutch relay plug, compressor will turn on, condenser fan will also turn on, my guess is the 10A fuse in the jumper will blow turning off the compressor, meaning the problem is the compressor clutch coil or the A/C CTP switch, the switch will be mounted to the compressor and is not removable on most compressors, wires on plug can be jumped for testing, reinstall compressor clutch relay, jump the A/C CTPswitch plug and turn system on, if fuse no longer blows it is the A/C CTP switch that is bad, if fuse still blows it is the compressor clutch coil that is bad, if it is the A/C CTP switch you can take your chances and leave the plug jumped if it is not the removable kind of switch, the coil will be replaceable, either way, coil or switch, the compressor will have to be pulled and that means a recovery and a recharge.94
fcm is offline   Reply With Quote
Cooling issues and fuse blowing 01 Civic Lx 01Civic88 Honda Civic (2001 - 2005) 3 03-21-2016 03:30 PM
HELP A/C condensor fuse keeps blowing bionichicken Honda CRX / EF Civic (1988 - 1991) 2 08-01-2012 10:04 PM
A/C fuse keeps blowing?? civic_nick2 Acura Integra 6 08-04-2010 05:59 PM
Air Condition issue lhd dc2 Honda Civic / Del Sol (1992 - 2000) 22 08-10-2009 07:59 AM
a/c condensor fan fuse keeps blowing FLCivic Honda Civic / Del Sol (1992 - 2000) 9 12-18-2007 05:37 PM
Tags
2000, 2004, 98, ac, blowing, civic, clutch, compressor, condenser, fan, fuse, honda, jump, motor, older
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
