97 accord Code P0715::: input turbine speed sensor??? NEED HELP!!! Please - Honda-Tech
Old 08-09-2004, 02:40 PM   #1
roydogg's Avatar
Default 97 accord Code P0715::: input turbine speed sensor??? NEED HELP!!! Please
My auto tranny isn't grabbing any gears so I scanned it and it came up 1 code which is PO715 the "input turbine speed sensor/ Circuit malfunction. Does this mean my tranny is bad? Or can I just replace the sensor?
roydogg is offline   Reply With Quote
Old 08-09-2004, 03:23 PM   #2
Chiovnidca's Avatar
Default Re: 97 accord Code P0715::: input turbine speed sensor??? NEED HELP!!! Please (roydogg)
Quote:
Mianshaft speed sensor.
Not very likely, but possible.
Could be a bad sensor, wiring, connector, or ECU.
Chiovnidca is offline   Reply With Quote
Old 08-09-2004, 04:10 PM   #3
roydogg's Avatar
Where is this mainshaft speed sensor located?
Old 08-09-2004, 08:20 PM   #4
Mike K's Avatar
do a tranny flush, and get the new sensor and install it.
so if you scanned that code, i am assuming you're a tech? most shadetree mechanics don't have PGM Testers...
if you're a tech, it shouldn't be an issue.
Mike K is offline   Reply With Quote
Old 08-10-2004, 12:33 PM   #5
roydogg's Avatar
Default Re: 97 accord Code P0715::: input turbine speed sensor??? NEED HELP!!! Please (Mike K)
I am a wanna be tech who has lots of friends in the industry that have no spare time but lend me their tools if needed. I depend on H-tech for most of my info
I also forgot to mention that I am getting a pretty loud whinning noise from the tranny. I'm assuming it's the mainshaft thats messed up. I don't wanna spend the money on the sensor then come to find out it's my tranny .
97 civic turbine speed sensor code xpdude Honda Civic / Del Sol (1992 - 2000) 8 07-16-2009 08:36 PM
97 accord se throwing code P0715 civicEXtreme Honda Accord (1990 - 2002) 2 08-13-2008 04:55 PM
2000 honda civic lx code p0420 tferro86 Honda Civic / Del Sol (1992 - 2000) 6 05-20-2008 08:13 PM
Honda Experts HELP: Tranny Issue sr20garcia Honda Civic / Del Sol (1992 - 2000) 5 12-19-2006 12:06 AM
Code P0715::: input turbine speed sensor?????? roydogg Honda Accord (1990 - 2002) 0 08-09-2004 02:41 PM
Tags
97, accord, circuit, civic, code, honda, input, inputturbine, mainshaft, malfunction, p0715, po715, sensor, speed, turbine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
