96' integra 1.8L cranking but only starts after 5 minutes of holding gas pedal
Old 07-13-2016, 12:23 PM
ToolJunkie21's Avatar
Default 96' integra 1.8L cranking but only starts after 5 minutes of holding gas pedal
I just replaced my fuel pressure regulator and my car is doing the same as it did before I replaced my FPR. have to hold the gas pedal down and continuously keep trying to start it until it finally starts. Could is be bad injectors or something.
Old 07-16-2016, 11:46 AM
holmesnmanny's Avatar
Default Re: 96' integra 1.8L cranking but only starts after 5 minutes of holding gas pedal
Could be a leaking injector. Holding the gas down puts it in "clear flood mode" which basically turns off the injectors so you only use any residual gas that was already pumped into the cylinders. Let the car completely cool down. Turn the ignition to on, to the one where the dash lights come on, but don't try to start the car. Turn the ignition off. Pull the spark plugs. Smell them for fuel. If one of them smells then you have a leaking injector.
It could also be a bad ignition system. Maybe you need a set of tuneup parts, cap, rotor, plugs.
Old 07-16-2016, 06:09 PM
I just put brand new wires on and the distributor isn't even a month old, fuel pump is engaging but should I look towards the injectors? Where should I look first
Old 07-16-2016, 07:38 PM
Rak1591's Avatar
find a noid light and check injectors, if all are good then check over ignition system
Old 07-17-2016, 01:51 PM
fcm
Old Fart
fcm's Avatar
Check fuel pressure.
Try this, turn ign. on and wait until fuel pump stops priming, turn ign. off and repeat, do this 3-4 times before trying to start the engine, [do not step on the gas pedal] any difference? 94
jdmhonDAftw
06-10-2008 07:38 PM
jjmajed
05-15-2007 07:12 PM
sik_sol
04-07-2005 07:14 PM
93JDMHONDA
05-12-2004 03:45 PM
mutt
07-14-2003 01:34 PM
Quick Reply: 96' integra 1.8L cranking but only starts after 5 minutes of holding gas pedal
