94 Accord EX Problem with Turn Signals/Hazard Lights
Old 04-09-2012, 12:40 PM
boostjunkieee's Avatar
Default 94 Accord EX Problem with Turn Signals/Hazard Lights
I cant seem to get either the turn signals or the hazards to work on my 94 Accord EX. I've replaced all the bulbs, replaced the turn signal relay, replaced the combination switch in the steering column, checked all the fuses and still nothing. None of the bulbs in the front or rear will light, neither of the turn signal lights on the gauge cluster light, no clicking noise.....nothing at all. Headlights, reverse lights and brake lights all work fine. I tried searching for the hazard flasher but I cant seem to find it, does anyone know where its located on this car? Thats about the only thing left to change. Any input or help would be greatly appriciated.
Old 04-09-2012, 04:21 PM
fcm
Old Fart
fcm's Avatar
Default Re: 94 Accord EX Problem with Turn Signals/Hazard Lights
Hazard lights and signal lights use the same, "flasher". [Signal/Hazard Lights Relay] power for both the hazard lights and signal lights go through the hazard switch, all the wiring after the hazard switch is common for signal and hazard lights.
Pull the hazard switch and test for a 12V+ constant, [hot at all times] hazard lights power, and a 12V+ switched, [hot in run and start] signal light power.
If you have both, the problem is the hazard lights switch, replace it. 94
Old 08-20-2012, 11:06 AM
DC2MeCZoom's Avatar
Im having the same issue, did you ever figure it out? im not getting no power from where the turn signal relay plugs in so might it be the wires? i change the switch itself like a month ago
Old 12-12-2012, 03:20 PM
Hektor's Avatar
Hello, Iam having the the same issue with my accord. I replaced the hazard switch and the combination switch in the steering column. The hazards work now but the turn signals dont.
were you able to fix your issue?
Were would the turn signal relay be?
Old 12-12-2012, 05:52 PM
Crx_owner_20's Avatar
And.. here you go.
rdemel
Honda Civic (2001 - 2005)
05-15-2017 05:26 AM
Corey Alfredson
03-16-2015 07:12 AM
Mesek_oner
06-02-2013 06:33 AM
sacjdmz
03-08-2006 09:27 PM
stupidwhitecat
11-05-2005 04:26 AM
Quick Reply: 94 Accord EX Problem with Turn Signals/Hazard Lights
