50A igniton fuse keeps blowing - Honda-Tech
Old 12-01-2011, 12:10 PM   #1
Teggerson's Avatar
Default 50A igniton fuse keeps blowing
Okay so I don't know if this could be my starter or my ignition switch.
So yesterday morning I went out start my car, and normally it cranks for like 5 seconds then starts up in the morning. This time when I cranked it, this burning metal smell came from under my steering wheel.
THE CAR TURNED OVER, and I drove it to work. When I left work like 5 hours later, turned the key to IION/Accessory dummy lights went on, but when I tried to crank it igniton fuse in the engine bay blew. Replaced it, did the same thing and it blew again.
Is there a way I can check to see if its my ignition switch or my starter?
Teggerson is offline   Reply With Quote
Old 12-01-2011, 12:11 PM   #2
Teggerson's Avatar
Default Re: 50A igniton fuse keeps blowing
Or is it possibly a short somewhere to the starter?
Old 12-02-2011, 02:52 PM   #3
Teggerson's Avatar
BUMMPPPP
Old 12-02-2011, 05:39 PM   #4
fcm
Old Fart
fcm's Avatar
The starter power itself is not fused, it could be a problem with the starter solenoid or wiring between the ign. switch and the solenoid, [possibly the starter relay or A/T gear position switch if it's an automatic, or the starter cut relay if you have OEM security].
I would start by doing a bypass jump, using a jumper with a 30A fuse in it, if fuse blows the solenoid is bad if not, leave the solenoid unplugged and unplug the ign. switch and do a continuity to ground test on the starter lead, [black/white], from both ends if it is a standard, either end if an auto.
If there is continuity to ground the starter lead has a short, if it is a standard and continuity is found at the ign. switch end, the problem is before the starter relay, if it is from the solenoid end the short is after the starter relay, if your car is an auto you will need to put shifter into a gear or unplug the A/T gear position switch and test starter lead from both ends to narrow down the location of the short. 94
fcm is offline   Reply With Quote
Old 12-12-2011, 04:20 PM   #5
H-T White Ops
NOFX's Avatar
Ever figure it out?
NOFX is offline   Reply With Quote
Old 12-19-2011, 01:04 AM   #6
Teggerson's Avatar
Yes yes, I followed all my wires from ignition and it splits into my alarm. I check my alarm wiring and found a fuse blown on my alarm. Since my car has remote start and the alarm blew a fuse connecting to the wiring to my starter. My alarm kept causing my car to blow the 50a fuse and not start.
alarm is blown maybe whiteboy-dc4 Audio / Security / Video 14 04-14-2009 11:33 PM
need help car wont start b1829 Honda CRX / EF Civic (1988 - 1991) 1 07-26-2007 03:17 PM
another starting issue, more electrical djbrandonr Honda Prelude 3 12-22-2006 06:21 PM
car wont start...Cifford alarm Dan Fizzle Audio / Security / Video 3 06-19-2006 08:06 AM
00 civic wont start (stumped) torr Tech / Misc 2 04-11-2005 04:58 AM
Tags
1992, 50, 50a, accord, blowing, blown, element, everytime, fuse, fuses, honda, ignition, integra, jump, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
