2005 Honda Element Wont start - Honda-Tech
Old 11-15-2012, 04:43 PM   #1
Default 2005 Honda Element Wont start
I paid 700 to get my element fixed and a new starter was put in as well as a replacement battery. It has been an intermittant problem but eventually just quit completely. Spent the 700 and it worked off and on still, starting most of the time but dragged for a couple seconds before starting. I bought an ignition switch replacement and just put that in. It still won't start. Dash lights come on, but it wont start. Ideas???? Can I bypass the ignition assembly and touch the neutral safety switch wires together and see if it will start?
funkygrl is offline   Reply With Quote
Old 11-16-2012, 09:44 PM   #2
Default Re: 2005 Honda Element Wont start
You can use a remote starter switch, directly from the battery to the small one pin connector on the starter. This will bypass everything and tell you if the starter is ok, provided your battery is good and properly charged. Did you get a Honda remanafactured starter? Check the power connections from the under hood fuse box, they are the screwed in connectors. Make sure the screws are not loose. If its a manual trans, check the clutch switch. If its an auto trans, shift into nuetral and try starting it.
MikeM is offline   Reply With Quote
2003 Element- what to look out for Stevo F Honda Element & CR-V 0 04-16-2016 07:27 PM
Starter issues Please help. JuneBugDrfter Honda CRX / EF Civic (1988 - 1991) 1 01-09-2014 12:03 AM
98 Civic wont start Johannes civic Honda Civic / Del Sol (1992 - 2000) 18 02-22-2013 10:45 AM
2003 Civic ignition . Binarymasta Honda Civic (2001 - 2005) 6 09-14-2012 03:02 PM
97 prelude ignition switch Scarface31313 Honda Prelude 1 04-28-2010 05:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
