99 Civic Engine noise.
Old 03-16-2017, 05:07 PM
LitoEK's Avatar
Default 99 Civic Engine noise.
First time on here just trying to get an another opinion on what noise is coming from my engine. I have a 99 Civic LX 4dr 5spd with a D16Y8 swapped into it. It runs great but I notice even when the engine is warm (not only cold) it sound like an engine tap coming from the valve train. I already adjusted the valves to Specs but the noise is still there just trying to get some other ideas. Thanks.
Old 03-17-2017, 12:28 AM
holmesnmanny's Avatar
Default Re: 99 Civic Engine noise.
It's possible you have an exhaust leak. I would seafoam it and look for white smoke billowing anywhere from the exhaust manifold to the oxygen, most likely from the exhaust manifold if there is a leak.
Old 03-17-2017, 03:31 AM
LitoEK's Avatar
It definitely doesn't sound like an exhaust tap. You can really hear it near the Cylinder Head.
Old 03-17-2017, 03:34 PM
pogeeboy27's Avatar
Take a video and post it up.
Old 03-17-2017, 08:36 PM
LitoEK's Avatar
New to this site how do I post the video I have one.
Old 03-17-2017, 08:50 PM
LitoEK's Avatar
https://youtu.be/zTcbjkzLz-I here's the video I posted on YouTube.
Old 03-18-2017, 10:35 PM
dazasero's Avatar
Just watched your video. Sounds exactly like my car after I replaced the timing belt. After discovering this god-awful noise, I tore my timing belt job down piece-by-piece and found that the tensioner pulley bracket's "tooth" had slipped out of it's "cave"... if you know what I mean (the tensioner pulley has a protruding square piece that sits in a complimentary square hole on your engine). So I reset the "tooth" back into the little indent, put the belt back on, and cranked her over. After about 20 seconds of the same dreadful noise, my idle slowed from around 1500 to 900rpm and the noise gradually went away. I don't know if this has anything to do with what you're working with, but I thought I'd share my insight just in case it helps. And out of curiosity.. how long ago was the swap done? Has it always sounded like this?
dakota1820
Honda Civic (2001 - 2005)
17
04-16-2013 07:01 PM
deerman2701
01-06-2012 06:54 PM
redm3turbo
12-19-2011 01:32 PM
512DOGG
05-22-2011 10:06 PM
SamC
10-21-2003 08:02 AM
Quick Reply: 99 Civic Engine noise.
