1995 EX sohc vtec, Timing belt broke... do i need new head?
Old 05-11-2003, 08:58 PM
JDMs1eeper's Avatar
Default 1995 EX sohc vtec, Timing belt broke... do i need new head?
I baught a 95 EX civic and the timing belt broke. Will i need a new head on that motor? do the valves clear the pistons to prevent bent valves and damage? what would i need? just new timing belt right? let me know thanks!
Old 05-11-2003, 08:59 PM
.RJ
.RJ's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (Typesi2nv)
install a new belt and r un a compression/leakdown test.
Old 05-11-2003, 09:13 PM
JDMs1eeper's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (.RJ)
Im not sure if it clears or not on this motor.... or if valves were at a posistion where they got lucky and didnt get smashed...
here is what happend
was at stop light.
light turned green.
i went,
car was going then lost power and turned off.
didnt make any noises at all like valves being hit or anything........
I hope its alright
Old 05-11-2003, 09:15 PM
wm5holla's Avatar
how do you know if you need a new belt?
Old 05-11-2003, 09:17 PM
JDMs1eeper's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (wm5holla)
when i try to crank it, it just turns over real fast like their is no compression and wont start. (plus when i took off timin belt cover... umm dead give away )
Old 05-11-2003, 09:30 PM
gulf imports
Guest
Posts: n/a
there most likey bent !
Old 05-11-2003, 09:32 PM
JDMs1eeper's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (gulf imports)
I'll find out tomorrow... i just didnt wanna have to pull the head and have to put a new HG on it if they were still ok
Old 05-11-2003, 09:39 PM
likaciv's Avatar
If you were cranking it, for sure the valves are bent, chances are some of the valves just so happen to be down when you were cranking the motor.
Old 05-11-2003, 09:43 PM
JDMs1eeper's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (likaciv)
never made any painging, knocking or noise at all indicating valves being slapped/bent... but i will find out...................
Old 05-11-2003, 09:50 PM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">how do you know if you need a new belt?</TD></TR></TABLE>
Old 05-11-2003, 11:31 PM
Malgerus's Avatar
If in doubt, replace. Sheesh. Replace it every x amount of miles (check manual). Not that difficult.
Old 05-11-2003, 11:42 PM
1_bad_EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv &raquo;</TD></TR><TR><TD CLASS="quote">never made any painging, knocking or noise at all indicating valves being slapped/bent... but i will find out...................</TD></TR></TABLE>
usually wont feel it unless you have conversion mounts.
Old 05-12-2003, 01:18 AM
00 FBP ItR's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (1_bad_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_bad_EF &raquo;</TD></TR><TR><TD CLASS="quote">
usually wont feel it unless you have conversion mounts. </TD></TR></TABLE>
umm... you hear pinging/knocking... you don't feel for it..
Old 05-12-2003, 05:48 AM
wm5holla's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (Mr. S)
Quote, originally posted by wm5holla »
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">If in doubt, replace. Sheesh. Replace it every x amount of miles (check manual). Not that difficult.</TD></TR></TABLE> how do u replace ur timin belt?
Old 05-12-2003, 06:26 AM
JDMs1eeper's Avatar
Timing belt is snapped... Imma replace iyt, check the valves, maybe replace head... oh well **** it lol paid $900 for the car and its in 100% and its a 1995 EX
Old 05-12-2003, 07:55 AM
Stripped Honda's Avatar
why dont you just turn the cam gear and watch each valve open and if any of them stick then you know you have a problem if you dont see any problems then you got a 75% chance the valves are ok
Old 05-12-2003, 09:20 PM
JDMs1eeper's Avatar
Default Re: 1995 EX sohc vtec, Timing belt broke... do i need new head? (Stripped Honda)
Grrrrrrrr... how the HELL do i get the crank pulley off?????? I have an automatic now so engine spins freely from wheels right?? how do i get it off w/ out having to use a high dollar tool. I dont have time to order the tool because i need it off tomorrow and this is my only transportation.... help please!
Old 05-13-2003, 07:32 AM
JimBlake's Avatar
Maybe take off the starter & wedge a crowbar into a tooth of the ring gear?
I had to take mine to a local garage where they used a air impact wrench... (I realize you can't drive yours.)
Cripton805
01-09-2022 07:15 PM
twentyhurtz
10-27-2009 05:16 AM
thunderboy
08-25-2008 04:19 PM
flat-blk-HB
01-05-2003 04:56 PM
Inaniac
10
06-15-2001 03:40 PM
Quick Reply: 1995 EX sohc vtec, Timing belt broke... do i need new head?
