195/50/15 vs. 205/50/15
Old 12-04-2002, 12:40 AM
New User
808State's Avatar
Default 195/50/15 vs. 205/50/15
I'm buying Bridgestone SO3 tires.
Is there a big difference with 195/50/15 vs. 205/50/15 tires? I'm currently using 205/50/15.
Will the 195's lower my stance much more than 205's? Is there much difference in handling with the two different size tires.
thanks
Old 12-04-2002, 05:11 AM
solo-x's Avatar
Default Re: 195/50/15 vs. 205/50/15 (hawaiiboy)
the imperceptably small increase in acceleration is more then offset by how much rubber the 205's put the road.
nate
Old 12-04-2002, 07:58 PM
97SactoLS's Avatar
go 205... a little more grip
Old 12-04-2002, 08:18 PM
itrSteez's Avatar
Default Re: 195/50/15 vs. 205/50/15 (97SactoLS)
go 205/40
Old 12-05-2002, 04:20 AM
Jeff C's Avatar
What about 225's? Are those too wide for a CRX with GSR wheels?
Old 12-05-2002, 05:06 AM
BROOD's Avatar
I had the same choice.......I went with the 205/50/15's
Old 12-05-2002, 10:41 AM
illusion's Avatar
Default Re: 195/50/15 vs. 205/50/15 (Jeff C)
i believe GSR wheels are only 6" wide.. 225 tires i would think would be too much. you really need 7" wheels for 225s.
Old 12-05-2002, 10:43 AM
Jeff C's Avatar
Default Re: 195/50/15 vs. 205/50/15 (illusion)
Yea, I figured that but I was hoping that someone would say that they had the same setup. I guess that I will settle for 205's also.
Old 12-05-2002, 01:12 PM
BeerMan's Avatar
Default Re: 195/50/15 vs. 205/50/15 (SLPR)
Old 12-05-2002, 01:23 PM
Chris N's Avatar
Default Re: 195/50/15 vs. 205/50/15 (BeerMan)
195/50's are much cheaper than the 205/50 S-03's. The large jump in price is just not worth using the 205/50's. Also, the 195/50/15 S-03's are very wide for a 195. The 205's would be VERY wide on a 6" rim. Not sure what your application is, but on my R, the 205/50's were too big for the stock rim. They were sloppy, and the 195/50 fit like a glove. Excellent tires, just not in the snow.
Old 10-18-2003, 08:00 PM
Reza.dc's Avatar
Default Re: 195/50/15 vs. 205/50/15 (Chris N)
if your wheels are 7.5 in width, can you run a 195 tire? or is that really asking for a problem
Old 10-19-2003, 03:26 PM
Jeff C's Avatar
Default Re: 195/50/15 vs. 205/50/15 (reza)
I am runnig a 205 on a '95 GSR wheel (7.5" wide, I think) w/o problems so I am sure you can run a 195.
Edit: Nevermind then.
Modified by Jeff C at 11:20 AM 10/20/2003
Old 10-19-2003, 03:56 PM
Reza.dc's Avatar
i think gsr rims are 6.5
Old 10-19-2003, 04:42 PM
Mohudsolo's Avatar
Stock GSR wheels are 6" wide.
efboy
05-06-2008 08:50 PM
GRANT!
09-14-2006 12:23 PM
ecahatch
01-27-2006 12:09 AM
Timmy!
08-12-2005 11:35 AM
akeldama
13
12-25-2002 08:36 AM
Quick Reply: 195/50/15 vs. 205/50/15
