12:1 compression on pump gas and octane booster?
Old 09-23-2003, 03:21 PM
jeremy.'s Avatar
Default 12:1 compression on pump gas and octane booster?
if i want to run at least 12:1 compression or higher on 91 octane...is it safer to add octane booster everytime i pump gas?
Old 09-23-2003, 04:24 PM
New User
TimoneX's Avatar
Default Re: 12:1 compression on pump gas and octane booster? (ek_jeremy)
It'll be safe if you have adequate fuel and timing maps.
Old 09-25-2003, 07:35 AM
jeremy.'s Avatar
after i am tuned...i just want to throw in octane booster since 91 is only available here....
Old 09-25-2003, 07:58 AM
LudeyKrus's Avatar
well' i've seen 12.5 H22's runnin 93 fine....but they were tuned. It may be possible to run 12:1 on 91 w/ good tuning
Old 09-25-2003, 08:07 AM
jeremy.'s Avatar
Default Re: (LudeyKrus)
nevermind....i realized octane booster doesn't do much.. .7 points rather then 7 points
Old 09-25-2003, 08:37 AM
warwagon's Avatar
Default Re: (ek_jeremy)
octane booster makes your damn plugs look all rusty
Old 09-25-2003, 12:20 PM
NA EJ1's Avatar
Default Re: (warwagon)
if you want to get by before tuning, use 1 gallon of toluene to 5 gallons of pump gas, and retard your timing a bit
Old 04-30-2005, 07:04 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">well' i've seen 12.5 H22's runnin 93 fine....but they were tuned. It may be possible to run 12:1 on 91 w/ good tuning</TD></TR></TABLE>
I wonder how bad it'll be running 12.5:1 on 91 Octane. Someone in California is selling a fully built block w/ 12.5:1 88mm
THC07
05-29-2007 07:26 PM
dvp95
06-09-2005 07:38 AM
k24a4kid
12-18-2004 04:13 PM
HondaGuy02
05-06-2004 11:37 AM
C4wrx
12-30-2001 06:30 PM
Quick Reply: 12:1 compression on pump gas and octane booster?
