Bench Compression Test Results
Old 09-01-2017, 02:33 PM
MastaFlyMason's Avatar
Default Bench Compression Test Results
Was planning on dropping a B18a1 into my car but I wanted to compression test it before hand. Looked into the cylinders and they all looked good, clean looking bottom and top end. I rigged something up to test the comrpession outside of the car I have the throttle body on and wide open battery charged and starter turning the motor over and I got cyl 1 around 60 and the rest around 90. I squrted oil into the cylinders and the compression didn't change. Is my motor toast or is it because it is a cold motor that hasn't run in a while?
Old 09-01-2017, 03:36 PM
motoxxxman's Avatar
Default Re: Bench Compression Test Results
possibly because it is cold and hasn't run in a while. I usually see much higher numbers though even doing a bench test like that. usually at least 100 across the board
Old 09-01-2017, 11:27 PM
holmesnmanny's Avatar
something isn't right, they should be atleast 100, there really isn't a big difference hot and cold
Old 09-02-2017, 01:58 PM
Just checked everything over, looks like the previous owner put a new timing belt on but didn't time it correctly. When put in time compression numbers look good. Thanks
blackccoupe
09-19-2007 04:20 AM
Got_soy
28
08-08-2005 12:49 PM
SPOON_FED_DC_2
04-06-2005 09:19 PM
staticrex
11-15-2004 01:30 PM
baboonstyle
10-29-2003 03:53 AM
Quick Reply: Bench Compression Test Results
