You CANNOT ride slammed AND have a smooth ride!
#26
Tickle-shits
Re: You CANNOT ride slammed AND have a smooth ride!
If you're slammed usually your car is going to handle worse...
#28
#29
Tickle-shits
But when you have a slammed car your suspension travel is limited, hence the car can only go so far before the suspension bottoms out which could be a disaster in a corner, not to mention, you need to leave space between tire and fender/quarters for the same reason.
#30
When suspension bottoms out, spring rate basically goes to infinite, which can cause things like tires suddenly losing traction while cornering. That's why it's so important to keep the suspension off of the bump stops and the UCA's from hitting the shock tower.
#31
"re: you cannot ride slammed and retain stock ride characteristics"
although, as i have done on several cars, you can. it just takes a lot of time and patience (and usually a saw and a welder) to do it.
#32
I guess the title should be 'you cannot get a good ride with our sponsors products'.
I can drop 3" front and 4" rear with stock shock and stock springs and still have full stock travel. No suspension bottoming.
I realize there are alot of brainwashed people here but instead of it can't be done, discuss how it is done and everyone can make up their mind if the work is worth the effort
#34
#35
#36
#37
wow, thank God I read that thread. I was about to buy a camber adjustable pillow ball mount to replace my anchor bolt camber kit. I guess I can put the stock anchor bolts back on and just get it re-alinged. sounds good to me. I always have trouble with my camber kit.
#38
Well IMO i didnt buy 1,000$ progress coilovers so i can drop it 2", mine is slammed and i have custom rear strut towers and thats it, i drove in my buddies car (same car as me) and it rides rough believe it or not. people always stop me and say how can u drive it so low, i said it drives litteraly like a cadi, and other people say well u have to stop over realroad crossings, Well this is the funnny part i got the worst realroad in my town and i acutally have a video on my fone goin 85mph over it and i didnt feel a thing nor my car bounce. so to sum it up never the less you get what u pay for!
#40
awesome thread... I was wondering if someone one here can educate me some? I have a TL and right now its lowered about 3.5 in front and 3.25 in rear since the car is so heavy it bottoms out a lot, I was wondering if upgrading my suspension to something like K-Sport, D2, Function and Form's, would have any affect in the car bottoming out so easy...? Does anyone on here have any experience with those suspension set-ups's? i hear a lot of good and bad things about every damn suspension set-up out there! comments are welcome!
#41
then change the thread title to be reflective of the topic you want it to stick to.
Thanks
#42
I have a CRX with an H22A that I recently swaped, I'm on coilovers, I dont mind the hard suspension of the stif springs, but what I mind is bottoming out with the extra weight of the new engine. I have a saw and a welder. Do you have any picutres of any CRX front suspension modified with saw and welder so it doesent bottom?
Thanks
Thanks
#44
Why do you need extended rear shock towers? The rear has way more room than the front.
#46
1st of all you dont no me at all nor my car.
2nd the extended shock towers are because my back used to bouce bad because im really low and a old freind of mind made then so it doesn't do it now!
But thanks for trying to flame!
#47
Ride like a Cadillac truck maybe? Come on man, the simple facts are that that sort of ride quality is NOT possible when riding slammed in a double-wishbone Honda.
Post some pics and specs (spring rates, etc) of your setup to prove me wrong.
#50
