Suspension & Brakes Theory, alignment, spring rates....
Wheel shakes a lot at highway speeds. NOT a wheel balance/warped rotor issue.
Old 01-17-2006, 08:58 PM
DoctorGSR's Avatar
Default Wheel shakes a lot at highway speeds. NOT a wheel balance/warped rotor issue.
The wheels/tires have been balanced twice. The semi warped rotors have been replaced. What else could be causing my steering wheel to shake so much when traveling faster than 40 mph? The whole car vibrates.
Could using the wrong lugnuts be the culprit? I'm using the ones I used for my GT3's for the steelies I have on now.
Alignment was also done recently too.
Any input would be appreciated.
Old 01-17-2006, 09:08 PM
vietnameeh's Avatar
tie rods?
Old 01-17-2006, 09:09 PM
Tyson's Avatar
Default Re: Wheel shakes a lot at highway speeds. NOT a wheel balance/warped rotor issue. (DoctorGSR)
steering rack end bushing for sure will cause vibration during braking at high speeds. it doesnt have to be a rotor "warpage" issue, but will cause rotors to go warped quickly.
do you have a swap?
Old 01-17-2006, 09:21 PM
DoctorGSR's Avatar
its not under braking. Its just whenever I'm traveling over 40mph. The wheel used to shake bad under braking, but I changed the rotors/pads and that has since stopped.
no swap, its a 97 GSR
Old 01-17-2006, 11:02 PM
oldskool teggy's Avatar
Default Re: (DoctorGSR)
AXLES. prolly bad passenger outter
Old 01-17-2006, 11:12 PM
Tyson's Avatar
ah, definatley not a reb issue then, since you dont have one.
i thought i was reading this in the crx forum... heh.
well, i have a few more guesses, but thats all they are with the info youve provided. axles is one of them tho.
Old 01-18-2006, 06:48 AM
chrisw85's Avatar
steelies are ball seat type and most aftermarket wheels are cone seat. Could also be your wheel bearings or a bad hub, and any other suspension bushings up front also the ball joints upper and lower. Tie rods have been mentioned, also think of the inner ones.
Old 01-18-2006, 08:16 AM
DoctorGSR's Avatar
alright i'll check on the axles and tie rods. the lower balljoints were recently replaced, and the uppers were replaced with omni upper a-arms.
Old 01-20-2006, 04:01 AM
AXLES
Old 01-20-2006, 10:18 AM
91' LS-VTEC's Avatar
Default Re: (Oldskool teggy)
what size tires do you have? Whats the tread at? jack up the car and spin each tire placing your hand on the tire. It might be separated.
Are you feeling a shake in the steering wheel or in the seat of your pants?
Old 01-20-2006, 10:19 AM
pingaturbo's Avatar
Also check the wheels to see if they are not bent somehow, take it to a wheel and tire, that can apply roadforce to the the to see if its any good.
Old 01-20-2006, 12:41 PM
Rob.'s Avatar
Default Re: (pingaturbo)
COULD BE BLOWN SHOCKS TOO.
Old 01-20-2006, 02:59 PM
DoctorGSR's Avatar
I asked my mechanic, he also said axles. I'll have the car up in the air in the next week or so.
the tires and wheels are both brand new. the wheels are steelies from tire rack and the tires are dunlop winter tires.
pretty much the whole car starts to shake at any speed over 50 mph. its more noticable in the steering wheel though.
Old 01-20-2006, 07:30 PM
.Ry
.Ry's Avatar
Did you recently put new wheels on? I have seen people that didnt use hub rings get a shake like that. Jack up your car and try and feel for play when you move the tire side to side and up and down.
Old 01-22-2006, 08:46 AM
rjgerolaga's Avatar
i had the same problem last week. time to change your axles. solve my shaking problem during acceleration on the highway.
Old 01-22-2006, 02:41 PM
DoctorGSR's Avatar
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">Did you recently put new wheels on? I have seen people that didnt use hub rings get a shake like that. Jack up your car and try and feel for play when you move the tire side to side and up and down. </TD></TR></TABLE>
i recently put the steelies and winter tires on yes. ill be able to get to the mechanic on friday to check it all out. thanx guys
Old 05-13-2006, 04:37 PM
Help we my pennies
BLUE EH3's Avatar
i have the same promblem , steering wheel shakes over 60 +mph and when i brake from 60+ is get WORST! i got my 2 front tire balnced . my rotors it feels like warped rotors
Old 05-13-2006, 04:48 PM
AutoXer's Avatar
Default Re: (BLUE EH3)
Just for info, in case anyone is searching out this issue; non hub-centric rims or mismatched lugnuts can cause wheel vibration.
I have VW rims for my snows, and their hub is larger than my civics. If I don't center the lugs properly to get the wheel centered on the hub properly, I get vibration. Hub centric rings would fix the problem as well.
Using the proper lugs for the rim will center the rim as well. Stock wheels use a 'ball' seat, and aftermarkets use a 'cone' type seat. Using the wrong lugs on the wrong wheel will cause stress points on both the wheel and lug nut, and possibly not seat the wheel properly on the hub.
skn181
07-01-2007 06:45 AM
teletekman
05-03-2006 09:15 AM
Fugeeu
08-20-2004 09:26 PM
redteg1
04-01-2004 11:24 PM
98ITR681
06-27-2003 12:06 PM
Quick Reply: Wheel shakes a lot at highway speeds. NOT a wheel balance/warped rotor issue.
