Suspension & Brakes Theory, alignment, spring rates....
damaged frame affecting alignment?
Old 04-05-2008, 10:42 PM
whteteg8901's Avatar
Default damaged frame affecting alignment?
this is for a is300
car has been pulling to the right and the front tires have been wearing out on the inside so I took the car to the alignment shop hoping to fix the problem.
camber and toe are within specs but the caster isnt. What could be the possible fix for this? what suspension components can change caster?
car is salvaged (hit on the right side)
please help, ive changed the tires twice in two years already!
thanks!
Old 04-06-2008, 01:21 AM
WhiteGSR95's Avatar
Default Re: damaged frame affecting alignment? (whteteg8901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whteteg8901 &raquo;</TD></TR><TR><TD CLASS="quote">this is for a is300
thanks!</TD></TR></TABLE>
thats your problem.
whoever did the alignment didint notice if the frame is messed up or bent parts.?
Old 04-06-2008, 03:45 AM
Reza^'s Avatar
take it to a body shop that has a laser frame rack and have them pull the frame back into spec , it will be easy to fix but the previous wreck is the culprit.
laser frame rack .. gl
Old 04-06-2008, 09:35 PM
thanks guys ill check it out first thing
vinuneuro
33
07-26-2008 08:44 AM
EG6R
Suspension & Brakes
05-02-2008 06:03 AM
20ls01
Suspension & Brakes
01-11-2008 01:52 PM
b16a2EBP
05-08-2006 12:47 AM
jolt-tsp
12-27-2003 11:47 AM
Quick Reply: damaged frame affecting alignment?
