Suspension & Brakes Theory, alignment, spring rates....
Use Honda Super Hi Temp Urea Grease on brake pads, is it ok?
Old 02-07-2010, 10:16 AM
skhell's Avatar
Default Use Honda Super Hi Temp Urea Grease on brake pads, is it ok?
Hi!
I have just bought some Honda Super Hi Temp Urea Grease to apply on the clutch spline when I replace the clutch on my Accord.
Is this grease ok to apply to the back of the brake pads?
Old 02-08-2010, 10:30 AM
skhell's Avatar
Default Re: Use Honda Super Hi Temp Urea Grease on brake pads, is it ok?
Anyone?
I guess that I will use the plain old copper grease...
Old 02-09-2010, 08:09 PM
kommon_sense's Avatar
I would not recommend the urea grease. The brake pads can get quite hot. I don't kow if the urea grease can handle the heat from the pads. Most auto parts stores sell small packets of anti-squeal compound for the back of the pads. That should be fairly easy to find.
Old 02-10-2010, 01:02 AM
skhell's Avatar
I have already looked at local auto parts stores and they don't have anything... I guess that I will have to order some from ebay...
Thanks for the help
Old 02-11-2010, 03:44 PM
TunerN00b's Avatar
Thanks for the help
Autozone usually has a small packet for $1 behind the counter if you ask. It is usually only enough to do 4 pads (2 wheels), so 2 packets for the whole car.
Old 02-18-2010, 09:51 AM
fonzo gte's Avatar
2nd that
Old 04-23-2010, 08:06 PM
pjladd04's Avatar
Icon3 Re: Use Honda Super Hi Temp Urea Grease on brake pads, is it ok?
No, instead get honda m-77 assembly paste at your local honda dealership. if not, your alternative is molykote m77. you can get it online for about $10-$15.
MilaniBlack
11-07-2010 11:29 PM
EG694Si
12-20-2007 09:49 PM
highmilehatch
04-15-2003 06:12 PM
serious
08-18-2001 07:39 PM
Quick Reply: Use Honda Super Hi Temp Urea Grease on brake pads, is it ok?
