brakes and funny noises
I have a simple question, when I apply my brakes which I've just changed, I hear an annoying sound like metal rubbing against metal. What could it possibly be?
Re: brakes and funny noises
they're new pads... and i had a very experience mech. replace the pads... so i assume that it was bedded correctly. But cant there be any other possible faults to cause this?
What Kind of pads did you use ? were they cheap or expensive ? Some times cheaper pads will always have increased pad noise. Most shops will waranty the pads if you tell them whats going on atleast I would. Is there any vibration or just noise ?
So, new pads, old rotors, and probably didn't get them turned? Try performing a proper bedding procedure and see if that corrects the noise. If that doesn't work, try deglazing the rotors with sandpaper and then re-bed them.
