Suspension & Brakes Theory, alignment, spring rates....
Suspension Gods answer me this
Old 06-05-2009, 08:55 AM
happycorey's Avatar
Default Suspension Gods answer me this
What is the point of a subframe brace, and a rear lower tie bar. I understand the tie bar may do one thing, and the subframe brace obviously braces the subframe, but together the tie bar seems useless. A subframe brace seems to do both the bracing.
So what is the technical functional use of both pieces? I assume the tie bar doesn't do anything but I've had friends who beg to differ.
Old 06-05-2009, 09:32 AM
PatrickGSR94's Avatar
Default Re: Suspension Gods answer me this
The answer is just what you thought: POINTLESS!!!!!!!! The ASR brace also acts as a tie bar due to it's size and shape, since it obviously ties both LCA pickup points together, in addition to providing a nice, flat spot for the sway bar D-brackets and reinforcing the subframe.
People who put both bars on there do it for looks, period. They either like the way it looks, or they saw someone else do it and like the way it looks. It DOES NOT provide any additional bracing.
In reality, running both bars costs more, weighs more, and reduces ground clearance, with no real benefits whatsoever.
Old 06-05-2009, 10:05 AM
STOCK_SOHC_DX's Avatar
JDM Bling Y0!
Old 06-05-2009, 10:15 AM
yep, pretty much... and it's not even a JDM part
Old 06-05-2009, 10:18 AM
That is true but it gives that illusion that it's the CTR bar.
Old 06-05-2009, 10:19 AM
hmm maybe.... wannabe JDM bling!
Old 06-05-2009, 10:24 AM
jasoncanseeoh's Avatar
It looks tight.
Everyone knows it looks tight.
Therefore everyone goes w/ this setup......sadly.
Old 06-05-2009, 10:26 AM
bleh I don't think it looks tight... I think it looks kinda dumb really.
Old 06-05-2009, 09:54 PM
happycorey's Avatar
Setup above is more appealing than a lot of other setups, but I don't like most tie bars. If anything a decent subframe brace, but that's it. Thanks though
Old 06-06-2009, 03:15 AM
alphalanos's Avatar
Kind of off topic: does anyone know if the D brackets in the picture are available separately?
Old 06-06-2009, 11:19 AM
yoontim23's Avatar
what he said.
Old 06-16-2009, 11:00 PM
Found a good reason for this now. To protect the ASR subframe brace!!!!
Old 06-16-2009, 11:28 PM
^Oh, damn. Legitamate. :D
Old 06-17-2009, 05:49 AM
alphalanos's Avatar
Wow, too low? I hit the front a lot, but the back never comes close.
Old 06-17-2009, 06:32 AM
phunhaus's Avatar
But it sits BEHIND the ASR brace so it only protects it in reverse.
Old 06-17-2009, 06:42 AM
hmm not sure what setup that is pictured with the scraped up bar, but it's not the same as the first pic. In that last pic the tie bar looks nearly even with the ASR brace's lower edge. With the Beaks tie bar in the first pic, it hangs MUCH lower than the ASR brace.
Whatever the car scraped, if there had been a Beaks tie bar there, it could have very well broken the tie bar, which could have caused subframe damage when it happened. This is exactly why you should NOT use a Beaks tie bar in addition to the ASR brace.
Old 06-17-2009, 10:46 AM
hickle's Avatar
but how can i be cool without my assortment of pointless annodized parts?
Old 06-17-2009, 10:04 PM
you can't man... you just can't....
Old 06-18-2009, 06:01 PM
Spongebrad Squarepants
Egezzy's Avatar
Old 06-19-2009, 03:16 PM
justfurebay's Avatar
^lol.
Ek-Xang
02-04-2010 12:30 AM
dc2ls-vtec
Suspension & Brakes
10-31-2009 08:07 PM
Live*JDM
Suspension & Brakes
12-20-2007 07:25 AM
ZUL8R
08-24-2001 10:05 AM
Quick Reply: Suspension Gods answer me this
