Suspension & Brakes Theory, alignment, spring rates....
Stumped...Humming noise from front end.
Old 04-19-2007, 01:53 PM
tunes12's Avatar
Default Stumped...Humming noise from front end.
I have a 98 CRV AWD 5 spd manual. The car has a fairly loud humming noise coming from the front end when travelling above about 30mph. Sounds like a tire noise or a bad bearing. It gets louder as I turn left and disappears when I turn right. I've rotated the tires and replaced the right front wheel bearing but the noise remains.
Everything I've read seems to point to the wheel bearing but obviously thats not the issue. Any other ideas?
Old 04-19-2007, 02:06 PM
Tyson's Avatar
Default Re: Stumped...Humming noise from front end. (tunes12)
yes it does seem like a likely wheel bearing issue.....
brake rotor dust shield?
Old 04-19-2007, 06:50 PM
PIC Performance's Avatar
How is your alignment in the front?
Old 04-19-2007, 06:51 PM
ramin_ksport's Avatar
more than likely wheel bearing.. get them checked out by a pro asap..
Old 04-20-2007, 07:09 AM
tunes12's Avatar
Default Re: Stumped...Humming noise from front end. (ramin_ksport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramin_ksport &raquo;</TD></TR><TR><TD CLASS="quote">more than likely wheel bearing.. get them checked out by a pro asap.. </TD></TR></TABLE>
I did have the bearing replaced, by a pro...Thats why I'm here wondering why the noise is still there.
I will check the alignment, thanks.
Old 04-20-2007, 07:14 AM
#1 Super Guy
94eg!'s Avatar
Perhaps you just have noisy tires? Off-road & performance tires make all kinds of noises over funny pavement. Then when you turn, all the tires spin at different speeds so the sound isn't as apparently droning (kinda goes away). Then once they are all going the same speed again you get a repetitive droning sound...
Just a though.
Old 04-20-2007, 02:07 PM
tunes12's Avatar
Default Re: Stumped...Humming noise from front end. (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps you just have noisy tires? Off-road & performance tires make all kinds of noises over funny pavement. Then when you turn, all the tires spin at different speeds so the sound isn't as apparently droning (kinda goes away). Then once they are all going the same speed again you get a repetitive droning sound...
Just a though.</TD></TR></TABLE>
Perhaps, but it wouldn't make sense that its only the front tires and that the noise goes away when turning right. The tires are all season regular nothing special, offroad, or performance, and they are new.
91EF_Si
11
03-13-2008 03:45 AM
tunes12
12
08-28-2007 04:54 PM
JDM97R
Suspension & Brakes
12
02-17-2006 02:02 AM
PAID-$$$
06-30-2004 09:12 AM
2SLO
11-06-2002 08:21 AM
Quick Reply: Stumped...Humming noise from front end.
