steering wheel turns left and right over bumps - Honda-Tech
Old 01-26-2011, 11:35 PM   #1
krazy one's Avatar
Default steering wheel turns left and right over bumps
as i go over bumpy/uneven roads, my steering wheel moves left and right and the car slightly swerves in the direction of the uneven/bumpy road. it happens sometimes when i approach a stop also. what can cause this? bad toe? unbalanced tires? the fact my car is lowered?(its not even slammed) TIA
krazy one is offline   Reply With Quote
Old 01-27-2011, 07:42 AM   #2
alphalanos's Avatar
Default Re: steering wheel turns left and right over bumps
Alignment most likely
alphalanos is offline   Reply With Quote
Old 02-02-2011, 11:10 AM   #3
krazy one's Avatar
anyone else has these symptoms?
Old 02-04-2011, 12:30 PM   #4
krazy one's Avatar
would toe play a role in this?
Old 02-04-2011, 12:44 PM   #5
alphalanos's Avatar
Quote:
Quote:
Camber and toe. Alignment
Old 02-04-2011, 01:09 PM   #6
BrowNKiD's Avatar
Could be what they call bump steer... Or worst case your rack could be going.
BrowNKiD is offline   Reply With Quote
Old 02-04-2011, 03:04 PM   #7
krazy one's Avatar
this might be related also, when i accelerate the steering wheel spins side to side a little.
Old 02-04-2011, 03:57 PM   #8
g230sport's Avatar
Sounds to me like your lca bushings are bad and who knows what else is worn out, best thing to do is get the car on a lift or up on jack stands. Shake the front end down, make sure there's no play side to side or up and down and just look around. Then report back
g230sport is offline   Reply With Quote
Old 02-04-2011, 05:18 PM   #9
krazy one's Avatar
i read the term "bump steer" and that matches my symptoms...
the spinning of the steering wheel only happens when im at a stop then accelerate and once i get into higher gears it stops.
Quote:
i did that many times, and my bushings are brand new urethane. i will report back when i take it to get aligned. thanks for all the feedback everyone.
Old 02-05-2011, 09:55 AM   #10
krazy one's Avatar
no reporting back yet, but has anyone else have had these problems before?
Old 02-06-2011, 03:52 AM   #11
89MA70's Avatar
I have had problems with the car pulling when going over bump and dips. Got new tires and alignment which that fixed it. When I traded wheels with my cousin his tires weren't in the best shape and my car started doing it again.
89MA70 is offline   Reply With Quote
Old 02-06-2011, 11:33 AM   #12
krazy one's Avatar
Im glad to hear that alignment may cure my problem. how about the steering wheel shaking left and right from accelerating from a stop? anyone suffer from this?
Old 02-07-2011, 09:18 PM   #13
krazy one's Avatar
anyone have a remedy?
Old 02-08-2011, 07:16 AM   #14
It's the fact that your car is lowered. Go to an alignment shop and zero out the toe. Depending on the drop it may be something that's always with the car.
SMHero is offline   Reply With Quote
Old 02-09-2011, 03:38 PM   #15
eklum's Avatar
check your balljoints . upper control arm has a balljoint and the bottom of the knuckle have one if your car has over 160k you probally need to replace them not a rule of thumb but every car i seen over that has had some sort of issue with balljoints, something to lookinto if u havent already..
edit: also the aboved mentioned get it alligned.
eklum is offline   Reply With Quote
Old 02-09-2011, 10:20 PM   #16
krazy one's Avatar
thank you all for the responds. so the bump steer can be due to the fact of the toe can be out correct? and the ball joint can be the issue for the steering wheel shaking left and right?
Old 02-09-2011, 11:45 PM   #17
eklum's Avatar
that is my understanding, shops have told me inner tie rods can have some sort of negative effect too, or if you have power steering something can get ****ed up idk a lot of people have no clue what their saying a lot of people do not. just start saving up and take care of any thing you can find wrong
Old 02-10-2011, 08:29 AM   #18
night's Avatar
wide rims riding half or less width on a ridge in the road will cause it.
caster changes from suspension movement will cause it.
night is offline   Reply With Quote
Old 02-11-2011, 05:24 AM   #19
96hb's Avatar
What kind of car is it? My car used to have the same problems you are describing (96 hatchback). My front end was pretty much used up with 200k miles on the clock, so I ended up replacing my inner and outer tie rods, my upper and lower control arms, and my lower ball joints. I also replaced the rack guide bushing inside my manual steering rack. Then I got an alignment. Another thing I did that really helped a lot was a rack guide adjustment on the steering rack. There is an adjustment nut under the steering rack that you can tighten to take some of the slop out of the rack (if yours is manual). Check into that first, as it's free to try, and then take it to an alignment shop and have them take a look. Find out if you need any of the parts I listed above. If you don't, have them do an alignment. My car was REALLY bad with what you are describing. When tie rods and ball joints start going out, the drive can be rather interesting. Good luck!
96hb is offline   Reply With Quote
Brought car in for work multiple times & still can't solve problem? Suspension issue? loki2323 Honda Accord & Crosstour (2003 - Current) 13 08-17-2014 06:12 PM
crazy steering on road grooves. Championship Acura Integra 16 08-24-2010 11:14 AM
thudd sounds on uneven roads IP RACING Honda Accord (1990 - 2002) 1 01-10-2010 10:38 PM
Side to side wheel play, rattle noise jmai86 Suspension & Brakes 3 07-19-2009 05:32 PM
Loose sub frame and rack and pinion jhfm Honda S2000 5 06-27-2004 10:06 PM
Tags
bump, bumps, bumpy, car, element, front, honda, lef, left, make, moves, pulling, shake, steering, turns, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
