Suspension & Brakes Theory, alignment, spring rates....
Squeak coming from rear of car
Old 05-27-2009, 04:07 PM
New User
phikshin's Avatar
Default Squeak coming from rear of car
I have a squeaking noise coming from the rear of the car. Usually happens when I go over bumps but does not happen every time I go over bumps. Sounds like its coming from the rear doors / Rear tires. I have a 1997 civic lx.
Any idea of what it could be? How to fix it? Any help would be appreciated.
Old 05-27-2009, 07:47 PM
xd69's Avatar
Default Re: Squeak coming from rear of car
Welcome to the club of random squeaks coming from who knows where. Ive tried to diagnose squeaks but the place they sound like they are coming from have NO moving parts, so i gave up and just turn up the radio
Old 05-28-2009, 12:37 PM
alphalanos's Avatar
Any modifications? Check all the bushings in the rear suspension arms. Bounce the car while its parked and see if you can hear the noise. You could try loosening the suspension bolts, then compressing the suspension with a floor jack and retightening, this reduces binding of the suspension bushings.
Old 05-30-2009, 07:00 PM
CG6Accord8o1's Avatar
could be endlinks, joints or bushings.
Old 05-30-2009, 10:25 PM
batallic's Avatar
could be blown shocks, torn bushings,
Old 05-30-2009, 10:53 PM
wannaBjdmca6's Avatar
is ur car lowered? check top hats ( the can separate metal and rubber part and move as there is suspension flex)
also trailing arm bushings, sway bar bushing.
good luck
Old 06-03-2009, 05:33 PM
2000BlueEm1's Avatar
could be your trailing arm the bushings might need to be changed, thats the problem with mine,cause my suspencion is new and it sqeeks
Old 06-07-2009, 07:46 AM
New User
phikshin's Avatar
Its a little hard to tell by the picture but thats the bushing in there correct? Because if so they all seem pretty worn out to me. Some of them look cracked / torn.
Old 06-09-2009, 04:51 PM
New User
vtecb20gsr's Avatar
trailing arm bushings squeak the most
Old 06-11-2009, 12:03 AM
dannyboi_86's Avatar
i replaced my suspension and had squeaks , i replaced the lcas and no more squeaks! , 2 weeks later another small squeak it was now the rear trailing arm bushes and now all good , but it may not be the case all the time but usually after lowering a car and being as old as our cars are its going to happen...
...Baker
10
06-10-2006 11:53 AM
...Baker
Suspension & Brakes
06-10-2006 09:30 AM
$amGD3
Suspension & Brakes
13
04-15-2006 10:47 PM
Rain_man
01-25-2002 03:07 PM
Rain_man
01-25-2002 02:38 PM
Quick Reply: Squeak coming from rear of car
