Ksport coilover softer springs?
Is there any way to get softer springs for my ksport full coilovers? Right now I have 9k/6k springs and it is really starting to get annoying with such a harsh ride.
If it is possible to get softer springs, what rates would be acceptable with a DD? I have 2 fingers of gap in front and rear. I also have a 94 integra if that helps any.
Re: Ksport coilover softer springs?
If they are standard 2.5"/64mm or 2.25"/57mm ID springs, you can use ERS springs from Eibach, available through Ground Control.
Solbros Owns Me
Hypercoil is a great alternative to ERS from Eibach. Less money with the same quality/longevity.
It's all I run now...we sell them individually also.
Just jack up one corner of the car and have a look. Spin down the spring perch if you need to in order to get them loose so you can get a tape measure under them.
would $80 shipped be a good price for a set? (2 springs), leaving the rear 6k
What rates should i get? I want the best ride possible, while not bottoming out. I have about a 1 to 2 finger gap in the front. Would 6k be too soft? i was thinkin 7k
