Suspension & Brakes Theory, alignment, spring rates....
HELP! Wheel Stud's broke...
Old 04-25-2005, 08:59 PM
SeattleBoy's Avatar
Default HELP! Wheel Stud's broke...
3 of my 4 wheel studs broke. I can't get the wheel studs out because the knuckle is blocking the bolt. How complicated is it to remove the front hub? Is there a way to remove the wheel studs without removing the hub?
Old 04-25-2005, 09:04 PM
Dan GSR's Avatar
Default Re: HELP! Wheel Stud's broke... (SeattleBoy)
https://honda-tech.com/zerothread?id=720159
Old 04-25-2005, 09:34 PM
SeattleBoy's Avatar
Default Re: HELP! Wheel Stud's broke... (Dan GSR)
THANKS!
Old 04-25-2005, 11:57 PM
RCautoworks's Avatar
You don't need a press either, you can use a slide hammer. I have done several and never ever had a bearing problem afterwards. As long as your know what your doing, you will be fine.
Old 04-26-2005, 03:42 AM
Lover
Audi RS4's Avatar
holy crap, may I ask how that happened?
Old 04-26-2005, 07:02 AM
Mike_C's Avatar
Default Re: HELP! Wheel Stud's broke... (Carparts-Auction.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carparts-Auction.com &raquo;</TD></TR><TR><TD CLASS="quote">holy crap, may I ask how that happened?</TD></TR></TABLE>
if the lug nuts are not tight there is A LOT of pressure on the studs... if one goes, more pressure on the others... and so on.
cmfnelson
11-24-2012 01:03 AM
jdmtodadc2
08-26-2012 01:21 PM
fit2slo
Honda Fit
10-28-2008 10:56 PM
Hulk_EJ8
11-15-2005 01:59 AM
Tokyo_X-treme_Racer
07-20-2004 08:10 AM
Quick Reply: HELP! Wheel Stud's broke...
