Skunk 2 lowering kit with cambers. - Honda-Tech
Old 11-29-2011, 10:56 PM   #1
Default Skunk 2 lowering kit with cambers.
I know absolutely nothing about coilovers. I'm new to the Honda game and I'd like to lift the car up a bit to take stress off the front axles considering I've already had to replace both axles. any information on how to adjust the coilovers would be great....or even just any information about them at all. BTW it is a 00 Civic Si
Michael_Robinso is offline   Reply With Quote
Old 11-30-2011, 03:25 AM   #2
Ek Forever y0!
Libertariat's Avatar
Default Re: Skunk 2 lowering kit with cambers.
Have you looked at the coil-overs? Not to be mean, but it's pretty self-explanatory.
It's really a matter of looking at the coil-over and going: "Oh"
Be aware the coilover should have an allen lock nut you'll need to loosen before the sleeve will thread.
I'm not sure if you have coilovers, or if you're looking at buying a set to replace your springs. But if you're looking at a new setup please take the time to read my suspension guide in my signature. It's objective, but it will at least point you in the right direction. Also what do you need to know about camber? Unless you have some crazy wheel fitment or are super-slammed, camber kits are unnecessary.
Libertariat is offline   Reply With Quote
Old 11-30-2011, 08:40 AM   #3
GagnarTheUnruly's Avatar
As Libertariat says, it's pretty obvious what to do. Put the car on jacks, remove the wheel, loosen the allen bolt, and use a pair of coilover wrenches to raise the perch. One turn is probably in the neighborhood of 1/16".
After you have the ride height set, check it on smooth level pavement, measuring from the center of the hub to the top of the fender, and make sure it is even. Then take it to a tire shop and have them fix the camber when they do an alignment.
GagnarTheUnruly is offline   Reply With Quote
Old 11-30-2011, 09:23 AM   #4
Ek Forever y0!
That is IF you have camber kits. If you don't have adjustable camber arms all they can adjust is your toe.
You may only need to correct your toe if you aren't super-slammed or have a crazy wheel fitment like I mentioned above.
Old 11-30-2011, 09:37 AM   #5
Sorry I didn't specify. Yes the car has front and rear cambers just like in the picture you posted. I did take a look at them but wasn't sure how they work. So the only tools I will need is an allen wrench and a coilover wrench?
Old 11-30-2011, 09:57 AM   #6
The Grumpiest
grumblemarc's Avatar
The image in the pictures are of COILOVERS. Not "cambers".
Follow the directions in the third post.
grumblemarc is offline   Reply With Quote
Old 11-30-2011, 10:00 AM   #7
Yes, and the ability to raise the car and remove a wheel. But the picture shows the coilovers, not the camber adjusters (which are just adjustable-length upper control arms). But that doesn't matter, because the alignment tech will adjust those for you to get the camber within spec. If it turns out you don't have them, the camber will be what it will be, but as long as you're not slammed it will not be a problem at all.
Old 11-30-2011, 10:01 AM   #8
^^ oops grumblemarc ninja-posted me
Old 11-30-2011, 01:00 PM   #9
Alright so I tried to move the coilovers and i will try my best to explain in detail what I did and maybe you can tell me why I got no results. I lifted the car. Took the tire off. Inspected the coilover. Cleaned the threads with a spray. Moved the second ring up close to the perch then moved the perch (or so I thought) and there is almost no difference at least that I can tell.
Old 11-30-2011, 01:14 PM   #10
The Grumpiest
Is the sleeve spinning when you do it? It isn't supposed to.
Old 11-30-2011, 02:36 PM   #11
Just to clarify, the perch is the gold part. I'm not sure what you mean when you say "second ring." If you screw the perch up the threads on the sleeve so that it compresses the spring, you will gain an inch of ride height for every inch you move the perch up, unless the spring was not preloaded correctly, in which case you won't get much ride height change until you're past the point of preload.
As grumblemarc is indicating it's important that you hold the sleeve steady or it will spin freely and you wont move the perch up the sleeve.
Old 12-02-2011, 12:47 PM   #12
Yes the right coilover moved pretty easily no issues there but I got to the left side and it was very difficult to move and then the whole sleeve started spinning
Old 12-02-2011, 01:18 PM   #13
The Grumpiest
A lot of Ebay "style" and Skunk2 coilovers have a second locking ring on them and you should have two adjusting wrenches. Without these you'll have a helluva time adjusting your ride height.
Proac'tive Coilover Sleeves? Any information? Mr Dark Sun Suspension & Brakes 3 11-09-2015 05:36 PM
Omnipower Backorder... Presto800 Suspension & Brakes 2 02-17-2008 09:11 AM
What axles work for a h22 civic swap? iv4hcx3l4 Honda Civic / Del Sol (1992 - 2000) 32 02-10-2008 08:06 PM
Autozone Remanufactured Axles. Bad rebuilds=Vibrations? CRXB16T Honda CRX / EF Civic (1988 - 1991) 11 11-10-2005 08:29 AM
K Speed Coilovers.. Boggie1688 Suspension & Brakes 1 03-16-2005 07:21 AM
Tags
2001, adjust, coil, coilovers, crosstour, crv, drop, honda, kit, lowering, ridgeline, skunk, sleeve, springs, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
