Suspension & Brakes Theory, alignment, spring rates....
Question about pressing in front bearing
Old 08-07-2013, 01:51 PM
OmarR's Avatar
Default Question about pressing in front bearing
I got front wheel bearings pressed today. I noticed the plastic seal on the bearing is facing outwards on one knuckle and inwards on another. From the factory, the plastic seal is facing away from the car. Does it make a difference that one knuckle has the bearing the other way around.
Pics to what I'm referring to:
plastic side of bearing faces towards car
plastic side of bearing faces away from car
Old 08-08-2013, 02:54 AM
Pullig's Avatar
Default Re: Question about pressing in front bearing
According to the manual it does matter. Plastic side out. One side is a 2 piece bearing the other is a 1 piece
Old 08-08-2013, 09:34 AM
sweesiong78's Avatar
yep bring it back and make them press it out and back in the correct way plastic side away from the car.
Old 08-08-2013, 11:10 AM
OmarR's Avatar
Will the bearing be damaged if it's pressed out and back in again?
Old 08-08-2013, 12:19 PM
it should not if they use a hydraulic press and the right sized bearing driver. it if was already on the axle than the inner race would come out but the knuckle has not been installed yet right?
Old 08-08-2013, 12:55 PM
OmarR's Avatar
Correct, I haven't installed the knuckle, was going to today but this holds back my plans.
Also, do you know the reason why the seal should face outwards? I'd like to have a clear reason for the bearing to be flipped around so the shop guy can't say something like it doesn't matter which way the bearing faces.
Old 08-08-2013, 09:44 PM
looking at the diagram both races are symmetrical so it MAY not matter, I read somewhere that the reason why they have a rubber side is just that during manufacture the assemble it from the metal seal side up, and then press the rubber seal into place.
I suppose you could insist to your mechanic that that's the way the service manual says it should be put on and then hope he is not too stubborn/grouchy....but I guess it depends how soon you need the knuckle on your car as well.
parahelium
Transmission & Drivetrain
06-08-2017 10:46 AM
Hellahflush
03-27-2015 05:15 PM
DaleW
05-26-2011 04:26 AM
rustanghunter
06-11-2010 07:29 PM
Quick Reply: Question about pressing in front bearing
