Suspension & Brakes Theory, alignment, spring rates....
How long does it take for springs to settle?
Old 05-01-2009, 04:22 PM
jrthestar's Avatar
Default How long does it take for springs to settle?
I put some agx struts with h&r race springs and i wanna no how long it takes for the springs to fully settle in? Their on my 94 ls
Old 05-02-2009, 09:14 AM
jrthestar's Avatar
Default Re: How long does it take for springs to settle?
bumppppppppppp
Old 05-02-2009, 10:44 AM
gosu08's Avatar
they take about 500 miles. that was with me...hope that helps
Old 05-03-2009, 05:15 AM
PatrickGSR94's Avatar
Springs don't settle. Bushings tear. You should always make sure you loosen all the control arm bolts that go through a bushing and tighten them with the car at ride height. If you don't, the bushings will be preloaded and eventually tear, which is what most people mistake for springs settling.
Old 05-04-2009, 06:37 PM
jrthestar's Avatar
I just want to know because my passenger front side is low and the rears a bit higher and then my driver side its the opposite the front is higher then the rear so i just wanna make sure they settle in
Old 05-04-2009, 06:51 PM
TunerN00b's Avatar
As has been already posted, springs don't settle.
Failure to correctly follow the manual and clock the bushings is frequently mistaken for "springs settling".
Old 05-04-2009, 06:56 PM
jrthestar's Avatar
How do you clock them? I just wanna have my dam ride at even height front same height and like wise for the rear help is appreciated guys thanks
GoLowDrew
Suspension & Brakes
03-27-2011 04:58 PM
asianalbutt
10-23-2005 11:38 PM
gofastgsr
03-23-2004 09:50 AM
LillDragun
03-25-2003 11:35 AM
Quick Reply: How long does it take for springs to settle?
