Suspension & Brakes Theory, alignment, spring rates....
Help!!!Brake pedal gets hard after driving for 10 minutes
Old 04-29-2014, 03:02 PM
  #51
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Default Re: Help!!!Brake pedal gets hard after driving for 10 minutes
A lot of times after replacing a master cylinder or brake booster, the rod on the booster has to be adjusted to allow enough travel to open the pressure release port and allow the brakes to return to normal position. This port can also be clogged by debris over time.
Old 04-29-2014, 03:15 PM
  #52
b16jared's Avatar
Or in my case replacing brake switch plug in the pedal with the flattest bolt I could find...not flat enough lol. The brake switch is what broke the plug so it needed adjusted anyway. I just adjusted the switch back instead of MC plunger.
Old 05-28-2021, 05:48 AM
  #53
Fkpoliticalycor's Avatar
Originally Posted by IGOTK22
I have 2001 honda civic dx....After driving for 10 minutes my car begin to slow down and stop....My brake pedal is hard as hell. Left the car for a couple of hours....Came back and the brake is functional again. I'm like Wtf!!!....Drove it home and its doing the same thing.
Does anyone knows what the cause of this....Thanks!
​​​​​​ I've been going through everything brake related on my 02 honda accord which had the same problem. Well ten minutes ago I found the solution. In the brake booster vacuum line, there is a check valve. I was barely able to push air through it. So check it out. There is a hardened, expanded area about an inch long. That is where I found my valve. Good luck
V-8 who
10-14-2011 08:49 PM
jwrape
05-25-2008 01:33 PM
DriveSlowHomie
01-31-2008 03:14 AM
dng
07-03-2005 09:24 PM
mikehawkBUiLT
24
09-16-2004 12:06 PM
Quick Reply: Help!!!Brake pedal gets hard after driving for 10 minutes
