Hawk PC Brake Pads: I Think I HATE Them...
This is my first experience with Hawk brake pads and I am just wondering if anyone has had similar issues/experiences with these pads. I also have done a lot of changes to my braking system all at once, so I am not placing all of the blame of my brake pedal feel on these pads. I had heard good things about Hawk brake pads and thought I would try them out (without doing any research . Now I am reading reviews on them and it sounds like these pads may be my problem.
First off, this is a '97 Civic hatch with a B20. I already had a BBK on it which consisted of 12" front rotors with Civic EX calipers and 11.5" rear rotors with GSR calipers. AEM pads all the way around (which now I'm starting to think I should have stayed with).
Here are the changes that I made:
Nissin 1" mc (brand new)
Cardon brake booster (reman)
'99 Civic Si prop valve (used)
'03 Porsche Boxster rear Brembo calipers (used)
'04 RSX rear calipers (used)
Wilwood front & rear drilled rotors (brand new)
Here is what I did:
Bench bled the mc before instal
Bench bled prop valve before instal
Gravity bled all calipers after install
Bled brakes w/ pneumatic (single person) LR-RR-RF-LF
Bled brakes manually (2 people) LR-RR-RF-LF
Bled brakes again pneumatically this time LR-RF-RR-LF
Adjusted booster push rod to mc (should have never touched)
Swapped in a different booster check valve
The issue:
Initial grip SUCKS!! I am now reading in reviews that this is an issue with Hawk pads. I mean, it's terrible. My initial impression was that the brakes feel stiff with nothing happening when applied. Another issue is I literally have to stand on the brake peddle to come to a quick stop from 40-60mph. It will stop, but it's a little scary! I can barely get the rears to lock up, and forget about the fronts locking up. Now I have only put about 40 miles on this new set up, but from what I am reading, it doesn't get much better over time. This is my project car and not my daily. I did want to get some performance out of my braking system, but nothing crazy, crazy.
So, here are my questions to you:
A. Has anyone had a similar experience with these pads?
B. What pads do you recommend?
Thanks in advance for your time.
Here is what I did:
The issue:
Cool Cool Island Breezes. BOY-EE
Re: Hawk PC Brake Pads: I Think I HATE Them...
Initial bite on hawks is usually pretty good. You sure you cleaned the rotors adequately? Got all the grease and oil off of there with brake cleaner? Did you bed the pads in? Anything wrong with the booster?
Does not improve at all. Although, I have been taking it on somewhat short drives. A few hard stops, or attempts at hard stops, and initial bite, or lack there of, stays the same.
You left all the oil on the rotor??? This would clearly be the issue if that's what you're saying.
You should always fully clean rotors and pads with brake cleaner before installing them. Rotors are coated in oil to keep them from rusting in transit.
It wasn't oil on the rotor. These Wilwoods came with an e-coating. It's a coating to protect against corrosion and there is nothing in the installation directions that says you must remove it. The pads do that as soon as they make contact with the rotor. I've worked for BMW now for over 10 years. They use a similar coating on their rotors which comes right off after a few stops. Never had an issue. This should not be the issue here either, but I could always try cleaning the pads off.
E coating should come off after some use, yes. I would clean the rotor and pad surface with brake cleaner. They may have sprayed oil on the rotor even though it was e-coated.
The pads are probably not the issue here. Did you do the maths on the changes you've made? You changed the brake system extensively and I worry you might have done more harm than good.
Not aware of any math I was supposed to do. I finally changed my prop valve from a DX to an Si due to going from rear drums to rear disks (something I should have done a long time ago). I wanted Bembo calipers up front and am using ones that my AEM BBK used originally back in the day. Due to the massive increase in piston area, I decided to move to a 1" mc to push all the fluid. Moving from GSR to RSX rear calipers isn't that big of an increase and is pretty straight forward. You'll have to elaborate on what I may have missed...
I can't write it all in a post but there are resources out there if you search. This one is as good a starting point as any (slide 9 in particular): http://www.sae.org/events/bce/daimlerchrysler-gritt.pdf
You need to size the master cylinder, caliper pistons, etc to generate proper braking force. You can't mix and match at random and expected it to work well... Good luck!
His master cylinder would have to be too BIG to not provide enough resultant force to the calipers. I doubt that's the case.
There is likely something wrong with his booster....or there's oil on the rotor.
I removed the pads and they looked a bit glazed over. So took the Drimel out and lightly sanded the surface of them. Feels like it helped a little. I've also read in reviews that the feel of the Hawk pads just take some getting used to. I guess I'll find out if that is true.
In the mean time, no one has suggested or recommended any other brake pads on here yet. What does everyone like out there???
I have zero experience with the PC compound from Hawk, but they advertise them as a dustless luxury/touring pad... Not an application where I would use a bite-y aggressive compound if I was in the business of making brake pads. Maybe you just need to try something more aggressive?
Ultimate stopping power in an ultra-low dust, low noise ceramic compound!
Hawk Performance offers a premium, high performance, ultra-low dust, low noise compound called Performance Ceramic.
Performance Ceramic is engineered to reduce brake NVH (Noise, Vibration and Harshness), creating a quieter performing brake pad. Furthermore, the ceramic brake pad formula has a linear friction profile that allows your ABS brake system to work more effectively. With Performance Ceramic you can expect reduced brake pad wear, lower dust output levels and a rotor-friendly brake pad.
Recommended for import domestic automobiles, luxury SUV’s, sports trucks & vans.
Today’s alloy wheel designs on premium vehicles has contributed to customer demand for a low dust performance brake product. Specify Hawk Performance’s Performance Ceramic brake pads for your luxury car, SUV, or truck.
All Hawk Performance Performance Ceramic brake pads provide a limited lifetime warranty, ensuring products to be free of defects from manufacturer’s workmanship and materials.
Thank you for the input.
My thoughts exactly. I should have done my research on these instead of just just going off of hearsay.
Ceramic pads always have less bite than their metallic or organic counterparts.
If comparing within the realm of ceramics, these likely bite better than most. You still shouldn't have to stand on the pedal to slow the car from 60MPH....even with stock calipers and pads. That indicates that there is something wrong beyond the pad compound not being agressive enough.
When you were comparing... I was assuming you were comparing apples to apples since Hawk has a billion different compounds. Their pads are generally more bitey than other pads of the same type.
Redstuff is a ceramic pad also.
Is this an application for a street-only car with a turbo? You're looking for pads with better cold bite? Any track use planned (road course)?
Your issue is that even with a FIRM pedal, you need too much force on the pedal to stop the car, correct?
