Suspension & Brakes Theory, alignment, spring rates....
ground control insulator replacement
Old 12-08-2011, 10:33 PM
TOO MUCH TORQUE's Avatar
Default ground control insulator replacement
ive been having this thump noise on my integra for some time now, it mainly occurs when i roll over reflectors on the freeway. I found the problem to be the spring insulator supplied by GC. This is the rubber padding between the spring and top hat. I can feel holes on my insulator. spring is making metal to metal contact with top hat.
My setup is koni with gc and OEM top hat. This setup has 65k miles on it only...
is there any aftermarket ones or should i just buy ground control's?
for people who dont know what the spring insulator thing is.
http://www.dsmtalk.com/forums/showthread.php?t=221601
i think mine will suffer the same fate soooner or later.
Old 12-09-2011, 09:58 AM
Default Re: ground control insulator replacement
no, the oem insulator needs to be removed.
Old 12-09-2011, 05:32 PM
The Grumpiest
grumblemarc's Avatar
Get them from GC or just search Ebay.
Old 12-09-2011, 05:40 PM
TunerN00b's Avatar
If you're ok with polyurethane (which is what GC uses to my knowledge):
http://energysuspension.com/universa...isolators.html
Old 12-09-2011, 06:20 PM
Andy@AMR's Avatar
We've got some that should work.
Old 12-09-2011, 09:40 PM
PM me price
i know its style A, but do you know which part number?
does anyone who uses ground control coils use it with OEM isolators? i dont see why it won't work...??
Old 12-12-2011, 10:40 AM
TunerN00b's Avatar
It works.
I am, in the rear where I kept the stock upper shock mounts.
Old 12-12-2011, 07:36 PM
how about the front? the front is where mine are pretty worn out!
actually i thought about this......oem insulators are thicker than GC's...so wouldnt that change my ride height thus affecting my toe?
Old 12-13-2011, 07:00 AM
The Grumpiest
Are we just making this a bit more difficult than it actually is or what?
Old 12-13-2011, 09:50 AM
TunerN00b's Avatar
If they do, it won't be significant.
However, since you'll be disassembling and reassembling the suspension to swap them, you'll want to align the car afterward anyway.
Old 12-13-2011, 11:43 AM
STOCK_SOHC_DX's Avatar
Call G/C tell them that you need new ones, here's the part #
G/C Spring isolator MO2770
*THEY WILL NOT SELL THEM IF YOU ALREADY DON'T OWN A KIT*
Old 12-13-2011, 11:54 AM
why would i need to align the car if i am not adjusting the height of the car? i would leave the adjusting perch alone..meaning i won't even touch the allen nut.
thanks
Old 12-13-2011, 01:34 PM
TunerN00b's Avatar
Why does a car need to be periodically aligned even if you don't change ride height or change any parts?
Any time you replace, adjust, or remove and re-install suspension parts, it's a good idea to get the car aligned. Alignments are cheap compared to tires and gas.
Old 12-16-2011, 12:51 PM
.I.Need.Money.'s Avatar
I have a sneaking suspicion that this is what's causing noise in the ***-end of my hatch.
GC/Koni with OEM top-hat, been on the car for about 6 years.
Would you notice any difference in handling with these being ripped?
Old 12-16-2011, 02:52 PM
TunerN00b's Avatar
No. All they do is try and isolate spring noise from the chassis. They don't locate pivot points like suspension bushings.
2.0L_of_fun
Suspension & Brakes
01-22-2010 11:20 AM
beanbag
Suspension & Brakes
09-10-2007 11:13 AM
mikeunreal2
12-27-2006 06:46 PM
R134
Suspension & Brakes
07-28-2005 02:05 PM
743power
03-20-2002 07:25 PM
Quick Reply: ground control insulator replacement
