Suspension & Brakes Theory, alignment, spring rates....
Alignment needed after top hat change?
Old 03-04-2014, 10:05 AM
TOO MUCH TORQUE's Avatar
Default Alignment needed after top hat change?
I have a 2001 integra coupe and i was wondering if i need an alignment after changing all 4 top hats.
I have koni/gc on oem top hats right now and i plan to get the gc top hats.
Thanks
Old 03-04-2014, 12:44 PM
KevinEF7's Avatar
Default Re: Alignment needed after top hat change?
yup
Old 03-04-2014, 03:45 PM
Runnerdown's Avatar
The top hat alone will not change the alignment, but a ride height change will.
Old 03-04-2014, 04:18 PM
Tyson's Avatar
^ this
its ride height that changes toe.
toe IS your alignment.
HOWEVER, inherently by swapping top hats alone, and thus raising the piston rod of the shock up, and provided you are just removing available droop, that in itself wont change your ride height.
it theoretically shouldnt.
but i wouldnt be surprised if you had to make adjustments to get the same ride height you had before because the two upper perches arent quite the same thickness either.
Old 03-04-2014, 06:12 PM
Thats exactly what i was thinking too. Either way, its probably best to do an alignment since i just got new tires too.
Old 03-04-2014, 06:39 PM
Tyson's Avatar
its always a good time to get a new alignment with new tires anyway.
Old 03-05-2014, 08:09 AM
KevinEF7's Avatar
And with the relative cheapness of the lifetime alignment deals out there. Id go 5 time s season if they were available here
2DoorBandit
Suspension & Brakes
02-18-2006 09:43 PM
AutoXer
Suspension & Brakes
05-18-2005 04:20 AM
ek4d00r
Suspension & Brakes
05-17-2005 03:40 PM
xtal
03-29-2003 11:26 AM
Quick Reply: Alignment needed after top hat change?
