Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Why is My Suspension Clunking?
Guide to diagnose trouble and recommended solutions
Clunking noise in rear
#26
Re: Clunking noise in rear
If anyone has rattles and cannot find it, and If you have Koni's, I would consider removing them. I had rattling in the front and rear. I found the front rattle this morning.. I swapped out the Koni shock on the front drivers side, and the rattle is gone. The Koni's have been rattling ever since new. like 4 years! insane. I had Koni's on the rear too at one time. In the process of isolating rattles, the rear koni's were also removed. So I am on Kyb+ eibach..
#27
#28
The clunking is common in a lot of Acura TL's, which have a similar setup of other Honda's/Acura's. So, that is likely a separate issue.
Too much negative camber can add to the cupping on the inside, but negative camber wont cause cupping by itself.
Blade_Irl
Suspension & Brakes
12-27-2008 01:21 PM
