Suspension & Brakes Theory, alignment, spring rates....
Brake Pedal Travel adjustment can this be adjusted?
Old 08-26-2010, 07:25 AM
Markb16a's Avatar
Icon2 Brake Pedal Travel adjustment can this be adjusted?
I have been trying to figure out what is wrong with my brakes. I replaced my master cylinder and now I dont have to pump my brakes anymore or seeping down at a red light. But now here comes the question this is too much travel before the brakes are pressed or engaged I should say. Would this have to be adjusted on the brake booster or the brake pedal assyembly? I dont want to raise the brake pedal any higher. But if this is normal, then forget everything I have said but for you guys is there any travel free play before your brakes are engaged? its about 2 to 3 inches for me right now.
Old 08-26-2010, 08:16 AM
hondawhiz's Avatar
Default Re: Brake Pedal Travel adjustment can this be adjusted?
you need to bleed all your brakes.
Old 08-26-2010, 10:16 AM
Drive 4 fun's Avatar
I don't know your specifics, but some MC's have a rod length adjustment when you put them in. Sounds like too much free play. Doubt a bleeding problem if the pedal is firm at the end.
Old 08-27-2010, 05:54 PM
Markb16a's Avatar
I already bleed the master cylinder and brakes over and over again. I want to say its a faulty brake booster. ok I got the problem solved with the master cylinder its not mushy anymore I dont have to pump the brakes but its firm when I hit the brakes. the only thing is there is a lil free play until the brakes are engaged could this be a brake booster issue?
Old 08-27-2010, 07:28 PM
hondawhiz's Avatar
you can go under the dash, follow the brake peddal up and you will see the rod that goes into the brake booster, you can andjust it, but i think your just noticing things now that u did it. just drive it and your mind wont even be thinking about little things like that. basically its normal to have small amount of play.
Old 03-20-2011, 05:59 PM
Markb16a's Avatar
So if I was to adjust the brake booster rod that would decrease the pedal play before actually engaging the brake pedal?
Stance Movement
07-30-2018 08:16 AM
Ueichi
02-25-2011 02:25 PM
bopbop93030
03-06-2009 11:38 PM
06civic_lx
01-04-2007 12:14 PM
yusoslo
12-15-2002 08:35 AM
Quick Reply: Brake Pedal Travel adjustment can this be adjusted?
