brake pedal goes too far down before braking - Honda-Tech
Old 05-20-2011, 05:21 PM   #1
swizz977's Avatar
Default brake pedal goes too far down before braking
how do i fix my brake pedal when i press it it has to go so far down before it actually starts braking 92 civic hatch
swizz977 is offline   Reply With Quote
Old 05-20-2011, 08:59 PM   #2
slowcivic2k's Avatar
Default Re: brake pedal goes too far down before braking
Quote:
Inspect the brakes, your rear shoes more than likely need adjustment. Provided you have not messed with the parking brake adjustment, your parking brake travel should be excessive as well.
If you have not done any work to the car recently, air is probably not likely.
slowcivic2k is offline   Reply With Quote
Old 05-22-2011, 03:31 PM   #3
swizz977's Avatar
its a stick
Old 05-22-2011, 09:52 PM   #4
A stick huh? please elaborate so that this thread does not mis-inform the next viewer...
Soft Brake Pedal, Lots of pad! bitter rod Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 10 08-28-2010 07:30 AM
serious problem with brake pedal pressure before and after upgrade byronl Honda Civic / Del Sol (1992 - 2000) 9 01-22-2008 01:55 PM
Mushy pedal / brake problem help please racekar Tech / Misc 10 11-07-2004 07:16 PM
I have a sinking/little resistance pedal after a new MC. Adjusting brake pedal pushrod? bad booster? TypeSH Honda Accord (1990 - 2002) 6 07-15-2003 03:13 PM
help, my brakes suck!!!???? yusoslo Tech / Misc 2 10-15-2002 03:02 PM
Tags
2008, brake, brakes, braking, break, car, faer, fix, peda, pedal, press, pressed, push, s2000, travels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
