Suspension & Brakes Theory, alignment, spring rates....
Blackworks Coilovers problem/shake
Old 06-27-2013, 08:31 AM
styqe's Avatar
Default Blackworks Coilovers problem/shake
After I got it installed I notice the tires shake side way. I check nuts/bolts and nothing loose. I even took it to the shop to check it out and the mechanic can't tell why it shake beside I had a bad outter tie-rod on the passenger side. I replaced both tie-rods and hope it'll solve the problem but it still shake. Could someone tell me the reason why it does that?
Thanks
Old 06-27-2013, 08:50 AM
been there done that
doood's Avatar
Default Re: Blackworks Coilovers problem/shake
you bought blackworks coilovers. that's the problem.
Old 06-27-2013, 09:43 AM
Hinta Project's Avatar
you HAD ebay coilovers installed at a shop...?
then you car shakes...?
facepalm.
If you can't install your own coilovers, and you're buying this kinda
stuff... maybe this hobby just isn't for you.
I would suggest you take your car back to this shop and have it returned
to stock. leave it be, and move onto something easier like collecting cards.
Old 06-27-2013, 09:52 AM
The Grumpiest
grumblemarc's Avatar
I'm assuming it was also lowered at the shop or later. Did you get an alignment?
Old 06-27-2013, 09:53 AM
kyden's Avatar
i'm not sure what the shaking has to do with the coilovers. what kind of car is this?
Old 06-27-2013, 12:14 PM
styqe's Avatar
it's RSX '02 ..
maybe the coilovers has the problem itself. when i loose the lock from coilovers, i can feel the treads aren't tight with the body(black metal part) as i move it up or down. ... I wonder if the site would do refund if that's the problem with their product.
Thanks.
Old 06-27-2013, 12:16 PM
styqe's Avatar
i had financial tight at that time and my car can't even take a turn w/o rubbing the front tires into the plastic guards undearneath. I did a little research on Blackworks and some dude recommended that's why i got them. Didn't know Blackworks gives me another problem T_T
Old 06-27-2013, 12:56 PM
doood's Avatar
there's obviously a language barrier here, so pictures would help us understand what you're having problems with.
Old 06-28-2013, 03:27 PM
EFSedan#6's Avatar
Hey now, I had my coilovers installed at a shop....the one I work at, by one of my techs.
There is obviously an issue to the OP. Get some pics so we can see if you might be TOO low and rubbing on some part of the car.
Old 06-29-2013, 05:28 PM
brettnahmann's Avatar
are the tires shaking when the car is jacked up? or when your driving around 55-60 mph?
GS-R Power
07-27-2006 02:43 PM
RSX48
09-27-2005 07:48 PM
tbud454
11-27-2003 11:27 AM
95vtecgook
09-19-2002 04:05 PM
Quick Reply: Blackworks Coilovers problem/shake
