Suspension & Brakes Theory, alignment, spring rates....
Best and lowest coilovers for 92-95 civic
Old 03-04-2013, 05:13 PM
jkemmerly05's Avatar
Default Best and lowest coilovers for 92-95 civic
I currently have a 92 civic hatch and im running koni and ground control. stock spring rates. i just wanted some peoples opinions on a full one piece coilover that would allow for as much drop or around the same and a good solid ride. in my mind nothing goes lower then koni ground control but i want a full coilover. so any help would be appreciated.
jkemmerly05 is offline
Old 03-04-2013, 05:19 PM
been there done that
doood's Avatar
Default Re: Best and lowest coilovers for 92-95 civic
Why do you want a full coilover if what you have works fine?
doood is online now
Old 03-04-2013, 06:54 PM
The Grumpiest
grumblemarc's Avatar
The hardparking points. Because other than that there is no reason in west Hades.
grumblemarc is offline
Old 03-04-2013, 06:59 PM
m_shake's Avatar
Just buy top hats and stiffer springs, don't waste money on another set of coilovers.
m_shake is offline
Old 03-04-2013, 07:36 PM
92egdxhatch's Avatar
Yep.
92egdxhatch is offline
Old 03-06-2013, 08:19 AM
what kind of springs? ive heard good about the swift springs. just cant find where to get em. and i like the ride of a full coilover versus mine.
Old 03-06-2013, 08:27 AM
Custom rate Ground control.
Old 03-06-2013, 09:57 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Best and lowest coilovers is a contradiction in itself.
Use what ya got and get stiffer GC springs and extended top hats as mentioned. Probably be your cheapest solution to what seems like a non-existent problem other than wanting a full body coilover. What is the reasoning for that?
speedjunkie_g35 is offline
Old 03-06-2013, 12:36 PM
TunerN00b's Avatar
We truly need a facepalm emoticon for this site.
YOU HAVE A FULL COILOVER NOW, JUST LIKE YOU DID WHEN THE CAR WAS STOCK.
The only thing affecting ride quality, if you aren't bottoming out, is spring rate and shock damping. Considering that you already have one of the best off the shelf shocks for any streetable ride height and spring rate, you really can't gain ride quality without jumping up to a $2k+ set of shocks.
And for those suggesting the OP get stiffer "GC springs", Ground Control doesn't make springs. They use Eibach ERS which are readily available from a number of sources.
TunerN00b is offline
Old 03-06-2013, 12:44 PM
Fliptard's Avatar
koni/GC is pretty much the best set-up there is, unless you wanna spen mad $$ on a suspension.
Fliptard is offline
Old 03-06-2013, 03:24 PM
The Grumpiest
Er, what?
Old 03-06-2013, 10:33 PM
92civiceg9gsr's Avatar
OP sell the Koni/GC to someone who can really appreciate them. Then order some one piece coilovers off ebay that are fruity rainbow colored.
92civiceg9gsr is offline
mondies_8
11-02-2011 07:50 AM
PA MATT
07-26-2003 02:07 AM
nighthunt6
16
06-10-2003 03:10 AM
spd18
10-28-2002 06:41 PM
accord ex
07-18-2002 05:25 AM
Quick Reply: Best and lowest coilovers for 92-95 civic
