ASR subframe/w Beaks tie bar. Question
2000 Si
Would I have any problems with installing both ASR subframe brace with Beaks lower tie bar, with my rear sway bar? If so what would i need?
I know i dont need both, but it looks good
Re: ASR subframe/w Beaks tie bar. Question
Would I have to get a 24mm sway bar also or can i use my 00 Si one? Im not sure wat mm is my stock one and can i use my stock endlinks?
What package do u suggest me to buy from passwordjdm.com or is there some were else i can get a good deal at lmk thanks guys
Same Problem...but for a 94 integra GSR..I think I will need a: Metric hex bolts, Metric standard bolts, Steel grade 10.9, 10mm x 1.5 x 110mm, according to my research. Am I correct? The factory size is 10x80..so I assume 110mm will suffice the length needed to thread all the way through?
And you can't use your stock endlinks...I had to upgrade mine to aftermarket adjustable endlinks because a 24mm sway bar is not compatible with factory end links. Additionally...I think passwordjdm is a rip off especially with shipping. I usually order from assaultech.com and jhpusa.com. jhpusa has a good deal on subframe/sway bar combos etc.
94b16coupe
Suspension & Brakes
01-04-2008 05:22 AM
